MyownScrambler
- Knoxville
- TN
Hello all, I have a new long block 258 in the 82 Scrambler and did a total swap from the old motor. When I pull into the garage after driving it and the cooling system is still under pressure and hot, there is anti-freeze bubbling from around the very front head bolt/stud. It only bubbles a couple of drops and then quits after the cooling system cools down. I would assume this is a head gasket but I cannot seem to see that as this is a new build block. Has anyone ever seen this on a new block? Does this mean the head gasket is actually bad? I re-torqed the two front bolts and it still leaks. Any suggestions?
Thanks,
Bill
Thanks,
Bill
