I haven't ventured far from home yet- it has has 265,000 miles and the axles and trans have never been gone through. The trans (T176) has a moderate whine and is real "notchy" between gears, the rear end has alot of slop, and the T-case could use bearings and seals. I've got a 700R4 that needs a 4wd output shaft installed and it's good to go, I'm planning on putting a 203 range box behind it and then the D300. I also have a D44 rear from a 90 Waggy, and a D44 front from a 1/2 ton Chevy. I'm narrowing the Chevy front to fit the Waggy axles, and then I'll install it SOA with high steer as it has the flat top knuckles. The D44 rear will go in as it sits SOA. This should get a pretty bulletproof drivetrain short of D60's, at a price I can afford (yeah, right!) I want to do it all at once so I don't have to get driveshafts changed more than once, I am about halfway there on building the parts, so sometime this summer it will all go in on a long weekend. Just trying to avoid "incrementalism", and I don't trust the drivetrain I have now, especially with the 350, to run it too hard. So I've been wheelin' close to home for now. But just give me time.......
