AAARRRGGHH! Head Gasket problems
Alaskan Postal nutjob
FORUM MANAGER
Ok, I FINALLY got the head on (I didn't take the manifolds out, they were just sitting off to the side, saving a ton of time) with the bolts lined up where they would go in.
So I start threading bolts in by hand working from the front of the engine... no worries until I got back to the 5th pair. The bolt went in fine, but the stud wasn't going. I got up on top of it all and looked down through the hole and the gasket DOESN'T LINE UP! Same thing on all of the rest of them!
It's really frustrating because the bolt at that position goes in fine but the stud is off by probably 1/8" or a little more.
What gives? I didn't think that there was enough play in the fit in the gasket that this could be possible. I tried to lift up the head and scoot the gasket around, but it just ain't happening!
I had to walk away because I was getting mightily pissed off.
Any suggestions? Is my gasket just wrong?
For the record in case anyone looks later, there apparently IS enough play that the gasket can be off that much. I came up with a system using 2x4's to span across the engine bay rods and 2 bar clamps to lift the head enough to finally move the gasket into place.
Here's a pic of the setup. it really worked great, one clamp is under the middle of the intake manifold, the other is inside the hole for the thermostat.
The final product after all that work, topped off with Kristy CJ-8's valve cover!
that last pic must be a negative, batteries on the wrong side (wink) LOL, J/K
Looks good!
