jscherb
- Elmira
- NY
Can you put a World Cab/Postal Top on a Wrangler Unlimited? I've been asked many times about this, so I finally took the time to document what's required. You can decide whether the answer is yes or no after you read this post.
Here's a drawing of a World Cab on a CJ-8 and on an Unlimited. Looks easy, but...
Because of the thickness of the TJ windshield and the "drip rail" design of the World Cab roof, in order for the WC roof to fit down over the windshield, you need an extra inch of length in the front part of the roof. (1). You can't just slide the roof panel forward on the side panels, because of the rise in the roofline (2). So you need to either lengthen the roof panel between that rise and the front, or you possibly could chop off the front drip rail on the roof panel and try to make the roof panel fit like the TJ roof does. Either way, non-trivial sheet metal work is required. I avoided this problem on the Retro, because I eliminated the rise in the roof, made a straight roofline, and slid the top panel forward (3).
Next, you need to find a way to attach the roof to the windshield, and most importantly, have it seal against wind and water. I used a Bestop header, and adapted the roof panel so it would fit properly. This involved cutting out the sheet metal that made up the "CJ-style" header so the TJ header would fit and finding a way to fasten the TJ header to the inside of the roof panel. I fastened mine with clips I made (one is visible forward of the header in the left photo), and automotive structural adhesive.
After you do that, and lengthen the front of the roof to be long enough, once it's clamped in place, the front of the roof will be 1/2" too high (4). I solved this by adding 1/2" to the top of my side panels in the back, shown in the right photo below. This wasn't too hard on the Retro roof, because my bottom roofline was flat, it would be a bit harder on the full WC, due to the rise in the roofline.
Also, shown on the left above, you need to make new upper door jambs, because the WC is made for "square corner" doors. The jambs I made adapt the top so standard "round corner" doors will fit and seal properly.
Speaking of fitting and sealing properly, the profile of the door jamb at the uppercorner of the door body is different. In the left photo below you can see how the jamb of the hardtop sticks out further than the jamb of the door opening. I reshaped the jamb at that point to match the shape of the TJ hardtop jamb. Without this change, the doors would be hard to close and may not seal properly at this point.
And finally, the CJ-8 WC is about 9" too long for the Unlimited (5), so you'll need to shorten the side panels and the rear of the roof panel.
So my answer to "Can you put a WC on an LJ" is yes, but for many people the answer would probably be no.
Jeff
Jeff
