Aluminum Valve cover installation help
Alaskan Postal nutjob
FORUM MANAGER
To any of you that have an aluminum valve cover that you've installed... I got one off of kristy (of the big yellow scrambler fame) but it won't have instructions or the screws to hold it on.
Anyone have instructions that they could copy here, scan in or otherwise pass along? And it would be a big help to know what size/length etc. screws I need to find to get this thing put on when I get my "new" head. Advice and/or tips are also welcome.
TIA
I may still have the instructions that came with
mine. Which part of Durham are you in? I might
be able to just run them by your place (If I can
find them). I assume this is still for a 258 right?
david
I'm off of Cole Mill Rd. north of I-85 by about 4 miles or so. I'd certainly appreciate it if you could hook me up with them.
I would be happy to meet you someplace to pick them up too. You can email me at bigwalton@earthlink.net
Oh, it is a 258.
Hey Bigwalton...
1st I followed your trip and wish I could have been there!
2nd Instructions for Aluminum valve cover. (wish my scanner worked, so I could post them, but it's on the frits, so if you want a fax of the one page let me know. It came from Rosner. I just put it on my motor yesterday.
Here's the highlights...
Parts needed:
5pc 5/16 x 18 x 3/4 allen head cap bolt
2pc 1/4 x 20 x 3/4 allen head cap bolt
2pc non studed rocker arm bridges
2pc PCV valve grommets
1pc oil plug
misc attaching screws for the stuff attached to the top of the cover
1) remove old valve cover and clean head. They recomend acetone
2) Remove studded rocker arms. loosen each bolt 1/4 turn at a time. Replace with non studded rocker arm bridges.
3) Test fit new cover without gasket. Check mounting holes to be sure they line up. You may have to drill and tap the two 1/4x20 bolts. DON'T DRILL TO FAR INTO THE HEAD.....duhhhhhh
Retap the remaining 5 - 5/16x18 holes.
4) Apply a spairing amount of silicone to both sides of the gasket and set on cylinder head.
5) Install new valve cover and hand tighten each bolt. Check gasket, is it still in the correct place. Tighten each bolt with allen wrench. They recomend a criss-cross pattern. Don't over tighten
Good luck.
Vinny
Vinny's directions are the same as the ones I have. One word of caution / advice. If you have to go out and buy a tap look for one that's made for a shallow hole because you don't have a lot of depth to work with. If your tap has a long leadoff point on it you will only have cut threads in the top 1/4 to 1/2 of the hole before the point hits bottom. Once that happens the tap breaks off in the hole which is the start of another ugly story.. Been there.. done that.. :-)
Good luck..
david
There's two types of taps, and for holes like this you generally need both.
The first type is a starter tap that's tapered like you mentioned. It's tapered like that to allow the threads to get started in a nice uniform fashion and to keep the tap centered in the hole. A starter tap would be fine for a through hole or one where you didn't need to go all the way down (you could drill farther in than you need threads).
The next type is a bottoming tap which is basically squared off at the bottom and is a uniform width the whole way up. This is for holes like I'm going to need where you can't drill through and you need threads all the way to the bottom of the hole (hence the name). You really shouldn't try to start tapping with one of these because it has a tendancy to catch in the sides hard and is tough to get started perfectly straight.
Whenever I need to do a hole I generally get both, even if I don't really need the bottoming tap, it makes a more complete set for the next time you need to use them.
This ends the tool tech section for today. We now return you to your regularly scheduled program... :D
Don't be surprised if you accidentally drill into the water jacket. I had this happen on one of my holes. The thickness of head material varies and this may lead to an unexpected drill through. This is not a major problem. There are several bolts that penetrate the water jacket. Just apply some high-temp RTV to the offending hole before installing your cover bolts.
Later,
Tom
Well that's a very good thing to know ahead of time. I do know that there are bolts in the water jacket... the one that's causing me to swap out my head is one of them. It would suck to have to drain the coolant anytime that I wanted to take the head off though...
