An experiance to live with-out....
1BADCJ8
Silver Member
Silver City
NM
Ok, since I got my tires and un-bent my drag-link and sleeved it, had to test it. I had to go run something. Another Scrambler owner here local was supposed to with me but he backed out so I wasnt gonna "not go". So I decide I'm going up the back side of Yankee Hill over which I've been a gazillion times. Get pretty far up the mountain and the snow starts getting pretty darn deep. No problem been there done that.
Well I'm getting up around 10,500 ft and the ATV tracks are all that remain... I push on. Finally it just gets too deep and I deside its time to turn around, especailly after I got the big grin from these ATV guys coming down.
Find a semi-wide spot that I can turn around in and start my back and forth turning, the snow in front of me was covering about 32in of my 37in tires. Up... back... got a little off camber not to bad.
ALL of a sudden I hear a huge rip and snap sound that ended as quick as it went of, no grind, no bang... just RIP/SNAP. I'm thinking what in the heck sit for a sec and then try to turn and my steering wheel is nothing, nada just swinging back and forth. I get out drag my self through thigh deep snow in the front and see one end of my "just worked" drag link pointing strait up at me.
"OH NO", as my mind is melting down, is the only thing I could think of (ok, after a couple min I went to thinking and saying a bunch of different things, but I wont describe them here. Your welcome... lol).
It bent really bad in front of where it bent before and we un-bent and sleeved it. Then behind that it simply snapped in half. Right where the original sleeve and rod came to gether... Snapp-ola.
Well I go to use my cell to make a few calls and it was on roaming and the battery was real low. So low it was ending any call I was managing to get to go though. Well needless to say I was pretty scared at this point. Scared to walk out or that I was going to get eaten by a bear??? No not at all but really, really scared to leave my Rig up there. I had visions of coming back and seeing a mear shell of what used to be a Scrambler.
To cut to the chase after hiking down about a mile to a clearing and a few calls with my wife telling her where my stock drag-link was and what else to bring me and a call to a friend of ours that just happens to have a 4x4 ATV, they were on the way up the mountain to rescue me... Thank goodness because it wasnt but about an hour or so till dark and I was getting cold fast.
Well Bill gets there with the part and all and I start to install it (had already taken every thing off after digging my self a snow garage infront. Well the low side, yep the one you cant change out, the threads on the tie-rod-end were bugered up pretty bad and the nut wouldnt thread... "GREAT". Well after trying like crazy to get it to go we finally realized it was up to good ole Mr. Cotter-Pin.
Stuck that cotter-pin in there bent the ends out and prayed that it would hold. Well folks that cotter-pin helt it not only for getting turned around all the way but all the way back down the very snowy trail and down York Gulch Rd, then down Fall River Rd... and down the highway, through town and to the house.
Adventure? Maybe but more scary than anything. I have already made a huge list of spare parts that will be purchased very soon. Including a drag-link :rolleyes:
DON'T FORGET THIS ONE!
NEVER WHEEL ALONE! ALWAYS HAVE ANOTHER RIG GO WITH YOU. ;) I don't want to get a phone call from your wife telling me you froze to death while out wheeling by yourself-JC;)
What type of steering setup are you running? DPA and stock draglink? DPA and correction draglink? Crossover? High steer?
LOL@JC
Oh no doubt. I could have walked out pretty easy but leaving the Rig is a last ditch thing. Would have never had a problem if the drag-link doesnt snap. Big but, but never stuck ;)
Jimmy just stock stearing with a custom made drag link in a semi S. Going chromeally this time and stay with this set up. Wont change the steering until I do an axel.
Dan you know it would sadden me if I was going up over the mountain only to see your rig frozeen in the tundra. Glad you made it out and back home safe. Even though Spring is coming it only take a few seconds of bad luck to have things change to a scarry situation in the high country. Did you have you standard getting stuck at over 10,000 feet gear on board? You did the right thing though. Stay calm and think things through. Also giving yourself something to do like dig out the front end and pull the old parts off while thinking about the situation and your next course of action.
One question will the parts list grow or shrink that you carry on board now that you made the SOA change? Just curious.
Hope you get the kinks worked out I want to check your Scrambler out and see all the work you have done.
If you'd just build yourself a little onboard welder out of an alternator you could solve lots of little problems like that. I've welded people's steering together 3 times, all were stock steering and the joints had pulled out of the sleeves.
Welder....
Yeah Ryan,
I'm thinking about buying a 2 stroke welder to put in my rig. But I'd really like to see what you have done if you dont mind writing it up, maybe draw some kind of diagram as well. I'd love to see that.
Tom,
Thanks buddy. I think it will be ready pretty soon. Better breaks in snow than on a rock later on. And yes of course I had plenty to keep warm for the most part. Got a little wet playing in the snow, but it was all good.
