Another 401
Guy in NC looking for a hunting rig on IFSJA...
Grantshire said:
This thing will be stripped and sent to the crusher (bodies too rough to salvage, but front clip is good) so let Ted or I know if you are interested in anything it might have.
Richard, Ted,
I noticed a "Wanted" post over on IFSJA.org today from a Tarheel looking for a Waggy/Cherokee for a hunting/trail rig. I posted there that he should PM you about this rig. Don't know how much work he's willing to put into it, but maybe they'll be enough left over for him to use as a base to start? And, I'm sure between the two of you (ever-resourceful guys :rolleyes: :D ), you can provide him w/ replacement pieces for all the goodies you cannibalize... :U :D
BTW Richard, I did finally get the cab & doghouse taken off that -10 I bought from you, and two of YOUR tires/wheels have also been removed... I'll get them down to you on my next trip (after upcoming NC trip) down thataways. :)
Ted Wendel said:
It's a widetrack,is that what you need?
That's the one John N said to use to cut it down 4" on the drivers side, or do I need a narrow track?
You can use a widetrack,the front wheels will stick out a couple of inches more per side,than if you used a narrow track.The leaf springs on a CJ are 27 1/2 inches center to center,the waggy's are 32 inches center to center,so you want to cut 4 1/2 inches off of the drivers side.
I use the narrow Waggy 44s, usually have to cut off about 4 1/16".
Thanks for the info, I guess I'll keep looking for a narrow track axle. Thanks anyway!
Tom
If you get to the point that you are tearing out the interior. I could use an automatic stering column.
One of the projects here will have an auto, and I could make use of it.
Carl
Carl,
I will let you know once we start pulling it apart. Right now it is still sitting on the trailer while the axle swap is under way.
Richard
