SgtMajHarper
New member
- Peyton
- CO
I've read every discussion thread I could find and haven't been able to find the answer to my delima.
I have an 83 Scrambler that sat parked for @ a year due to some body work and tail light / turn signal issues. It ran fine when parked, gas gauge worked also. This last fall / winter I got the other work completed finally but when I got the Scrambler running now the gas gauge doesn't work. It just "ticked" up a little when the key was turned on, nothing else. I had a full tank of gas in it when parked, checked the hot wire going to the sending unit and had power, thought maybe the sending unit went bad or the float sank to the bottom and read empty. So, I ordered a new sending unit, dropped the tank, pulled the old sending unit, float had "some" gas in it, not much or enough to be my problem. I tested the old sending unit and all readings were good. So, I put the new float on the old sending unit and put the tank back up, went and filled it up, gauge still reading empty so I figured the gauge went bad/ I got a new Rugged Ridge gauge, installed it, made sure the wires were correct.
Now when the key is turned on, the fuel gauge goes from E and pegs hard left below E. In the off position it returns to E like normal. Same when engine running or just key on. Someone somewhere had a post saying that the polarity was reversed on these after market gauges (sounded odd) and to reverse the wires. I had tried everything else, so I figured I'd give it the smoke test. Didn't make any difference, did the same thing. I put the correct wires back where they belong with the same issue and I am befuddled.
I keep reading remarks about they never work, get used to it, etc....... I've had Jeeps since the 70's and they all has working gas gauges, some were even replaced, but they still worked.
Ideas?
Ideas?
