Anti- Rust Products
Dave K.
Milwaukee
WI
Since my LJ Rubicon is so minty I want to preserve the frame and underside the best I can. What products have you all used that you would recommend short of spraying bedliner products all over the underside (not my thing). Thanks for the help. Dave.
I am using this stuff on my fj40 I am doing now.
http://www.shop.masterseriesct.com/product.sc?productId=1
Has a lot of aluminum in it, like por15 but suppose to be a lot better, if scratched to the bare metal that scratch might rust, but the rust will not creep beyond that scratch. Instructions even say can be applied over marginally prepared surfaces. I have put some on some parts I just wired brushed about 2 years ago and they look just like the day I applied it. Where I dripped it on some plywood it is still there, it is like a chunk of aluminum permanently bonded to the wood. Very impressive stuff from what I have seen so far. Seems to be very popular product for people restoring bugs based on internet research. All very positive reviews, where you will find lots of people complaining about por15 problems.
Eastwood makes an anti-rust product that comes in quart and aerosol cans (you can get the extended spray nozzle that is used on their internal frame coating. The stuff leaves a waxy like layer that has a satin black finish and is supposed to be self repairing. I have never used it but the reviews on it are all good! I have been very happy with all the Eastwood's products I have used, I can't imagine why this one would be any different!
http://www.eastwood.com/ew-heavy-duty-anti-rust-qts-black.html?reltype=2&parent_id=1429
I have used the MasterSeries Master Coat on my Grand Wagoneer and Scrambler. To test it, I sanded the front fender down to bare metal, put on 2 coats of Master Series, and then drove it nearly 8 months (in the salt through the winter). No rust bleed through at all!
But, that material needs to be applied directly to bare or rusty metal.
For the painted portions (and undercarriage) of the Grand Wagoneer and after completing the renovations on the Scrambler, I plan on using:
http://www.rustcheck.com/
move to SE Utah or southern AZ or NM?
I have had several with a variety of sprayed on tar based undercoating type material and none maintained their integrity over time and once the coating was penetrated they all seemed to trap contaminants and water between the metal and coating.
I have heard that the ziebart coating worked quite well, but I dont know if it's still available. I have also heard that some of the zinc based thin coatings work well and I had heard that some of the sacrificial anode based systems actually work well in their application.
I try to keep mine washed off fairly frequently, that, the very low humidity, the no winter salt and the steady persistent oil based fluid leaks help keep my jeep rust to a minimum
For just a quick spray projection to prevent rust, Ive had good luck with Boeshield T9 and Corrosion Block. The T9 leaves a wax film behind....cant really see it, but it seems to work. I spray behind the hinges, in joints, etc.
