Anyone ever seen tank tracks for a CJ-5 before??
I know there was a company making tracks for different trucks, not just Jeeps, but they were real expensive. Unless you live at the North Pole, I just don't see how it could be worth it. More like an expensive conversation piece for rich guys.
Holy crap, I'd LOVE to see those installed! Working them would be a PITA without a lot of fabrication on the controls though I would think...
I was also expecting Mattracks: http://www.mattracks.com/
Other than the north pole, you would need these anytime you need a lower psi footprint.
Suppose these things have a contact patch 10 times more than a tire. If you neglect the added weight of the tracks (I know they'd weigh a good bit, but for illustration's sake), they'd have 10 times lower psi on the ground.
That means that you could float over things that tires would dig into and you will theoretically do less damage to the ground you cover if you're not spinning the tracks (turning would probably tear some junk up though). They're not just for snow although they probably work better than anything on snow. Cool to do an ATV as a snowmobile without spening cash on something that will sit many months of the year...
Neat to have as an option for certain circumstances.
The only problem I see with those tracks is that they don't look like the have independantly articulating "wheels" inside the tracks on the ground side.
So you would feel every bump and end up rocking forward and back quite a bit.
I drove a M119 APC for 3 years in the military, I know my tracks......:p
I saw an old pic of a M715 on tracks. Some demo a company did for the army, I"m guessing that didn't get a contract. I'll see if I can dig that up. It had four small sets of tracks, looked like three wheels in each set.
I have seen other versions that wer eon ebay about 4 years ago.
Actually it was the whole jeep for sale. But the track treads were aluminum or sheet steel with less mas. They were designed more as a snow cat.
The weight of those heavy cast treads would make it pretty hard for a small jeep. Wonder what they were originally designed for.
Carl
