I did a lot of research and decided to do an EOR from weld in cage to go under the half hardtop. Has anyone put one of these in? If so I would love to get details and pictures.
http://www.eoronline.com/store/jeepscram.shtml
The rear hoop seems just a tad to wide. I can flex it in but the 5 point bar will not fit. I will have to grind it a tad shorter.
The floor plates for the rear hoop will not fit in between the side support and the other support on an original cj8 body, neither of which I think a CJ 7 has. That also could be part of the first problem. I will have to trim the foot pad about half an inch and drill new holes. Would love to see a picture of the rear and front foot pad locations of an installed EOR front cage.
Also I would like to see or know where the 5 point bar should go as well as the dash bar. How high should I put the 5 point bar. I have a padded dash should the dash bar be above or below or left off.
Thanks for any help on installing the EOR cage.
