Anyone moved their ignition control module?
Depends on what someone means by "HEI swap"
Some people swap in an HEI distributor with HEI module (module is part of distributor in that setup) whereas I did the "TFI" or "Team Rush" with new cap, rotor, plugs, wires, coil using my original distributor, and then only used the HEI ignition module to replace the original duraspark module.
