anyone run 304/360 in CJ8? what exhaust?
MyownScrambler
Knoxville
TN
I have been contemplating going to a 304/360 setup and wondering if anyone is running this combo and what exhaust you are using. I have headers and stock manifolds and need ideas or even better pics of exhaust setup on the Scrambler.
thanks,
Bill
360 with stock manifolds, Y-pipe and single pipe out the back. I like it quiet.
Is is just a factory type Y pipe to just in front of skid plate on drivers side and then muffler and tailpipe out the driver rear? What size ? 2 1/2"?
Bill
I don't remember the pipe size and I won't be home for a few days.Design-wisw is like a stock 304 CJ type system.
What John said.
Use Manifolds to keep em tucked in tight if you want an in frame system. Passenger side crosses over just behind the T/C into the Y-pipe on the drivers side. The muffler shop made my Y-pipe. Not sure the size, I would have guessed 2"
304
I run a 304 in my Scrambler. It has an off road cam Edelbrock performer intake, 4bbl and Edelbrock shorty headers that are a direct replacement for the stock exhaust manifolds. I have full dual exhaust inside the frame rails then exiting out each side behind the rear wheels. I have had no problems with this setup and it is quiet.
I use my rig as a daily driver I get between 14 / 15 mpg on the highway with AC. I am also running an AMC 999 automatic transmission and a HEI distributor.
There is no REPLACMENT FOR DISPLACMENT
Good Luck
Mike
I'm running Borla Headers, and glass packs, i could get you pics if you really care.
Mike, sounds like you have what I probably want to run. I will use the factory manifolds so I don't have to spend $$ for shorty headers and I have the manifolds. Mine will be a daily driver also and the dual exhaust would be semi quiet depending on the muffler type. Too bad you cannot get a pic or two from underneath and send me.
thanks for everyone's input on this.
Bill
