Are there any manufacturer markings on alumninum replacent tubs - Aqualu or Matkins?
sevensandeights
sevensandeights
Mckean
PA
In my quest to find a replacement tub I found somebody about 3 hours away that has an aluminum tub for sale. This guy doesn't know anything about Jeeps but said he bought it new from a guy at a swap meet. The tub supposedly came from California and has all the factory holes pre-drilled.
Is there any way to tell who made this tub? I would rather know who made it and if it is a quality tub before I drive 3 hours to look at it.
After searching this forum, I know Matkins made aluminum Scrambler tubs that were predrilled so it could be one of those but I don't know where Matkins was located. Also - he said he paid about $4500 for it several years ago and Aqualu tubs (imported for JP Offroad at the time) were much less expensive a few years ago.
My Aqualu tub didn't have any markings in it, but I can now easily recognize their construction from a quick look-over. Aqualu doesn't pre-drill any holes except for the transmission tunnel, and the seat-belt retractors.
My understanding is that the Matkins firewalls were punched out on a press and are therefore curved, while the Aqualu tubs are flat sheets that were cut and welded. I've never seen a Matkins tub in real life, but I think if you've got an aluminum body with a curved firewall, that certainly means you don't have an Aqualu tub.
Thanks - the tub I am considering also has the ridges in the bed running front to back like the OEM one so it is most likely a Matkins.
My biggest concern (especially after talking with Rudy from this site - he has a Matkins tub) is that for some reason, the guys at Matkins did some crazy grinding/DA sanding to the entire exterior of their tubs. Rudy said there were gouges as deep as 1/8" all over the tub and that he had to put a skim coat of body filler over everything and then sand down the high spots.
Here are photos of our AQUALA CJ8 tub before we installed it on Dad's CJ6 10 years ago. Below are current images.
