Attempting to see if I need a rebuild on my engine
I-20 304
New member
Monroe
LA
Got back from the mechanic only have a small few things along with a exhaust leak and a gasket leak I was told
You got no heat too, lines have been cut. Not that you need in LA.
I had them redirect my heater core because I was leaking coolant and antifreeze after the radiator got replaced
That's a lot of bolts holding that valve cover to the cylinder head for a 258, I'm thinking maybe a 4.0 head or at least valve cover??
Supposedly it’s to rusty and they didn’t wanna touch it in case it broke so I have to bring it to a muffler shop
Looks like you need a battery tray or you have a strange aftermarket battery tray.
Good chance there is a weber carburetor on the engine also.
I have the battery battery around the house I just thought that one died and needed a replacement for now but I have the tray on there
