AX15 or NV3550 behind AMC V8 looking for real world success vs. failure experience
Scott_P
Benzonia
OK....so after the last 1000 mile + round trip to the UP of MI and back, I've decided its time to do something about the noise and comfort level in my Scrambler. Thought about looking for a nice LJ...but why spend all that coin?
Can't do much about the wind noise from the soft top...but I can swap in an OD transmission
I am running a mildly built AMC 401/T-176/Dana 300 with D44's locked front and rear 3.73 gears on 33's. At 60 mph I am in the 2300 rpm range...great for the power band, but a little on the high side long trips on the Hwy. Would like to drop a few hundred rpm.
Most of my wheeling in this vehicle is expedition style...some hwy, forest roads, light and medium off-road...no real hard core (as in body damage) rock crawling, but not afraid to go anywhere. I usually pull an M-416 on these trips.
After studying several posts in this forum, and the fair amount of info on swapping an OD trans in, I am considering an AX15 or NV3550. Have not ruled out the NV4500. Unfortunately, have not found much info on how the finished swaps are working out.
So, how are things holding up for any of the guys who have swapped in the AX15 or NV3550 behind V8's or radically built 4.X L six cyl's....regrets? Wish you had gone NV4500?
Thanks for any input!
I'm looking at doing this same swap behind my SBC 350. The downfall to the NV4500 is its size.
Sent from my SAMSUNG-SM-G850A
This is something going through my head as well. I currently run an ax15 behind my 258 and I love this transmission. I have a sbc in my 5 and have considered the swap. Novak says it's a good move and the ax15 can handle it and for the type of driving I do I think they are correct. Now if foot to the floor mud bogging is in order then this may not be a good choice but I bet these will hold up fine for medium duty wheeling.
Fighting with the JK crowd on a rare HD drop in transmission keeps those things high. I don't think it's half the trans of a nv4500.....
Doing some research now....but from what I have found the T-176 was conservatively rated at 270-285 ft-lb of input torque. THe AX15 and NV3550 are rated in the 300-315 ft-lb range. Somewhere I found a chart for these (newer 5 speeds) that specifies/rates the transmission max. input torque (300/315 ft-lbs) at (XXXX lbs.) load, but I can't seem to find the link again.
The AX15 and NV3550 have very similar gear ratios to the T-176 which I like, w/the 5 spds having a slightly deeper 1st gear...NV3550 being the deepest. Again not a bad thing.
If anyone comes across a nice link to the input torque specs. please post up!
[QUOTE= I don't think it's half the trans of a nv4500.....
Kinda different animals, sorta. The NV is a truck tranny. Everywhere but off road or Towing very heavy it's not much more than a 4 speed.
The NSG is more Driver oriented. You can use all 6 gears (if the rest of your driveline matches) and shifts more car like. But at the loss of crazy-crawl first.
All things have trade offs. *shrugs*
Sent from my SM-N930V
I have run an NV3550 behind several v8s in states from stock to slightly massaged. I am running one now behind a ford 5.0 that makes right at 300hp at the wheels.
You are right on with the torque specs. The AX-15 and 3550 are similar rated. The NV is rated just over 300 ft/lbs input at 7300 lbs GVW.
I have used this transmission in rigs that saw more street than trail and I have not had any trouble with them. Something else always broke first since I had not done oversize or chromoly ujoints, high spline count axles, etc...
I have been running the one I have now for over 1.5yrs and I am certainly over the torque rating in ft lbs. But I am way under in GVW. So even with lockers and 35s I have not had a problem.
I do not wheel the hell out of this rig though. Challenging trails yes, but not punishing.
I have also run an NV4500 in a more hard core wheeling rig I had prior. It is not even comparable to an NV3500. The 4500 is a truck transmission. It is sized like one, weighs like one, and shifts like one. It is the way to go if you are more concerned with breaking stuff offroad than how it drives on road.
Here is a size comparison:
cbford (and everyone),
thank you for all your input and verifying the rating. With the Scrambler weighing in at a little over 1/2 of the 7300 gvw, I'm sure we can bump up the input torque and get away with it. If my research is correct on the T-176 rating and assuming its rating is at a similar gvw, I'm satisfied that the AX15 or NV3550 will work out well. My T-176 has only failed me once and it was total driver error....the rear output shaft did not like my launch at the drag strip one time. The NV4500 is sweet, but probably over kill for my needs.
Now the hunt is on for parts!
And cbford...I noticed in your setup picture that you are running what appears to be a "normal" throw-out bearing fork and I assume linkage...what set up is that? I was figuring I may be forced into using a hydraulic set-up.
Looks like a Lakewood bellhousing/scatter shield?
Don't discount the hydrolic...much nicer to the knee in traffic. ;)
Scott-p;
The Bellhousing is a Lakewood for small block ford that holds the Ford truck 164 tooth flywheel and uses an 11 inch clutch.
To make the NV3550 work with Ford engine; I used the 11inch Ford Centerforce pressure plate which holds an 11 inch - 10 spline dual friction disc for chevy application. I used the standard late 80s ford truck clip-type clutch fork and throwout bearing.
All that is operated by the stock mechanical clutch linkage Jeep gave us, which I reworked with rod ends and retention springs so it wont pop apart if I twist it up some.
If I had been planning for very hard offroading I would have gone hydraulic instead of mechanical on linkage.
Recently swapped a nv4500 behind my fuel injected 401. World of difference. Picked it up from advance adapters rebuilt. 6.32 first with 29 spline output to tcase. Used a 11" centerforce clutch. Shifts like a truck yes, but feels much more civilized vs the T18 it replaced.
Just scored an AX15 for $150...if I don't use it in the 8, I'll be putting it in my 64 wagon behind the 4.0L.
Now I just need some time to start mocking things up!
