Axle, etc. painting?
Alaskan Postal nutjob
FORUM MANAGER
I didn't think that this topic fit very well in any particular forum, so here it is...
Anyone ever painted their axles (or any other heavy-wear part)?
I have a new D30 housing that even I couldn't put on the Jeep without wirebrushing and painting. I just don't know what to use on it. POR-15 seems like overkill to me (and $$$) as it's not like it's going to rust through like a frame would...
I was thinking that the paints like Hammerite sounded promising...
I'm willing to prime and paint to do it right, but I'm going to need to keep it low buck somewhat too...
Thoughts and suggestions?
GO WITH THE POR
Eric, I know that it's kinda pricey, but you'll be happier with the results if you use the POR. The cool thing about the stuff is that it now only rust-proofs, but is pretty bomb-proof as far as chipping, cracking, or flaking off.
You can even bend the stuff while on the metal and it won't chip, axles grinding over rocks will make short work of your pretty new axle paint!:p
The other thing that I'm afraid of with POR (other than the POR on the HOOTUS :D) is exactly that I WILL like it, a lot.
I know exactly what I would do if I got started in on POR... I'd see how well it works and protects on the axles and then I'll want to be doing it everywhere. Next thing I'd know, I'm poor from buying POR and the postal is scattered all over the garage in a mad frame-off rampage.
Ugh... maybe rust isn't such a bad color after all...
I've used appliance enamel in a rattle can. Sprays well and lasts longer than standard spray paint. Couple bucks more per can though. Nothing will hold up to serious wheelin though.
Home Depot sells large cans of Rustoleum industrial spray paint. I buy the High Gloss black by the case. I have it on all of my Jeeps axles and bumpers. I just wire wheel everything wipe it down with laquer thinner and spray away. The best part is if you scratch it, which you will, then you can easily do a respray after every few trips. I personally have never resprayed and everything still looks great. You can use the red oxide primer in the same can if you want to prime first. I have done it both ways and not seen much difference. Axles are never going to rust away so I personally don't see the need for fancy paint. Maybe on your frame. All of my D44s are from 77 or 79 Cherokee models, and they painted up just like new after 25 plus years of abuse road grime. A great thing to have while spray bombing is one of these:
Spray Can Handle
They really keep you from wearing out your finger. I could spray a whole Jeep with one of those.
Later,
I agree with Tom. I used POR15 on my front and it only lasted a year before it started peeling off. I used the rustoleum "hammered" on the rear a year and a half ago and it's held up great. I've used the stuff on rims, bumbers, axles, crossmembers, the only thing it didn't stick to was the frame but that was my fault for not prep'ing the galvanization.
Now that's what I wanted to hear... lacquer thinner and Rustoleum (or the like) it is...
I'll get into POR-15 at some point, but I just know I'll get in over my head if I start in on it now. As it is, with spray paint, I am already going to have to convince myself that I need to make the rear axle pretty too since I'm doing the front. With POR, it'd be "Well maybe just the axles and skidplate... well, how about the bumpers... hmm, the frame looks like it could use some right over there... if I could just lift the body a little I could get that spot too..." and on and on... :D
Oh, I already have those handles for the spray cans, I use them with the white I paint the body/top with. They're incredible!!
I've been using all 3 paints mentioned on my resto. I POR'd the frame. Hammerite'd the rears and Rusto'd the bumpers. They all look good. I chose hammerite for the rears for the ease of spray bombing it. It looks good and is thicker than the rusto. I also thought it would be easier to touch up than POR. Only bad thing about it was the tips clog pretty fast. After about half a can they clog. I had some extra tips so I just swapped them instead of trying to keep cleaning them.
