Axle problem? Grit on my splines...
MomoJeep
Seattle
WA
So my AMC20 rear (1pc axles) started leaking out the passenger side. I was stupid and let it go too long and cooked the bearings. I was unaware. Stop light turns green and I bring up the clutch and nothing happens. No noise either. The cooked bearing let the axle slide out of the differential side gear. I get towed home. I use front wheel drive to get into the parking spot but I do hear a small grinding sound in the rear.
I take it apart to see busted up wheel bearings pieces. There is an inner bearing seal also, so the bearings are packed, not fed by the differential gear oil. I pull out the shaft to find metal grit on the end of the splines. I don't think this came from the busted wheel bearings, since they are at the other end, and on the other side of the inner seal. I'm afraid the grind sound I heard was the tip of the splines just barely grinding on the diff side gear (since the shaft had already slipped entirely out of the side gear, then maybe got pushed back up against it (but not into it). OR the splines were rotating around inside the tube and scraped it up? The axle splines themselves look fine (strong alloy). See picture. Should I be worried? Should I open up the differential?
