- Denver
- CO
I'm starting to think about the rebuild of the axles. They have clearly been leaking out of every seal for years so I think all new bearings, seals, ball joints, and u-joints (also one-pieces in the rear). I think I'm going to stick with the stock 3.54 ratio since the #s from the calculator look pretty good with the AX15/Dana300/31" tire combo I'm planning to run. My question is, can I re-use the stock gears if they are in good shape? I ask b/c I was told recently by a local shop that "generally it is best to replace the gears also as with new bearings we will very likely end up a few thousands off on the pattern from were it was. Idea being if we reuse the gears our goal is to try and replace bearings without moving the gearsets. Instead of setting to a good pattern."
Is that legit? I'd like to save a the few hundred bucks on new gears if I can and I don't know enough about diff gear setup.
