I can't get my head around the water part. I know they say metal prep and wash off with water (same as one might do after an phosphoric acid treatment) but I just can't bring myself to put water where rust wants to get busy i.e. A newly blasted frame. :dunno:
I kinda figure there isn't a better surface for paint to stick to than sharp freshly blasted steel. We used to have machine frames (salty water RO plants) blasted then phosphoric acid, allow to dry, zinc rich wet spray then Powdercoat over that. The idea being the phosphoric stays "active" and in the event of a Powdercoat chip the phosphoric would arrest and rust. The zinc rich prime's selections was since it is the only spray primer that can handle the heat of the powder coating process.
If u make the metal prep dry without washing it turns to white ash. The por degreaser is great also as it comes in a gallon and you have to dilute it .. i use it on everything.
This explains it best. https://www.youtube.com/watch?v=-yA8q4K-_Bo. Quick wash with water (while ospho is wet) then dry with rags and compressed air. If ospho drys, you have to re-wet to get it active then wash with water. I've done it with just drying and then epoxy and the white ash gets on the metal and doesn't allow the epoxy to get a good bond. Wash with water and no problems.
