sevensandeights
sevensandeights
- Mckean
- PA
I bought a near mint used frame this past summer that already had a set of Chief Wahoo's reinforcement frame plates welded on. The plates look good and are super beefy but many of the pre-cut holes are slightly misaligned. I bought a Harbor Freight die grinder that came with some stone type bits. These worked good on the larger holes but do not fit into anything 1/2" or less. I bought the only set of "carbide burrs" that I could find between Lowes/Home Depot/Tractor Supply and they did not work well and are also bigger than 1/2" in diameter (the die grinder can spin up to 20k rpm but the burrs are only rated to 2.5k rpm!).
Any suggestions on the best way to do this. I only need to take about 1/16" off one side of the holes for the motor and shock mounts. If the die grinder is the way to go, any suggestion on the correct bit for the application and where to buy them?
