bikini top and channel
spaxton
Springfield
Any opinions or advise for buying a winshield channel and bikini top for an 81 CJ8. Do they fit the same way as on a 7? Difference in brands, etc?
I've had the hard top off a while but need something just in case of the afternoon boomers.
thanks,
Shawn
A CJ-7 and an 8 are the same in this aspect. I'd recommend the strapless bikini over the standard ones. Brand - can't remember who made mine.
I've never had a bikini top (insert joke here :D ), but I am going to get one sooner or later, also. I like the look of the of the standard ones better. Why do you recommend the strapless?
Thanks
-Mike W
Unless I'm mistaken, the strapless is the only one you can use on an 81 Scrambler. The 81 doesn't have the small loops at the base of the rollbar kickers that bikini tops hook to. I have the old Whitco top that was sold at Jeep dealers, with the AMC/Jeep logo on it. The straps wrap around the top of the kickers.
Have besttop
I have a Bestop Strapless on my 81. You do need to have a footman loop at the top inside of the windshield for the middle strap that goes under the rollbar and up to the footman loop. I tried to go without that strap attached and it does flap around quite a bit.
as for traditional, I would think you could buy 2 footman loops and attach them to the bed somewhere to secure it. There only a couple bucks, too.
for my opinion, never had a traditional, but I do like the strapless. Keeps out more than I thought it would, especially with the doors on. My only concern is that the top of my windshield is rubbing on the bikini, and I am affraid it will eventually wear thru.
just my $.02
I have Best Top with straps on my 81. Then again I bought my Jeep its Bikini Top over 10 years ago. It only sees about 2-3 months a year that I use it. I have large eye let bolts mounted in all four corners of my bed and just loop the straps through the one at the base of the roll bar. you can just see it in this picture. you can also see how I store my High lift in the bed with out it sticking out, or being in the way while the top is on. I store my axe and shovel on the other side in a similar fashion.
I might have to take a look at one of those new fangled strapless jobbies for the old girl to run around in??
As for the channel over the windshield. Try and find a solid one piece from a soft top or ask if you have a choice? In the past they always came with 2 piece window frame channels which I felt where pretty lame.
I use a strap type on my CJ-7 and do not use the footman loops. What I do is kind of wrap the excess of the bikini arround the roll bar underneth the part that would be directly touching the bar. Basically ads about a wrap and a half. Then I take the strap and run it through the crotch of the vee in the bar and back to the buckle.
It is harder to describe that it is to do. but it seems to work very well. What I do have that I reall ylike is a "Top Prop", from skid row. Basically it is a fiberglass bow from a boat cover that goes from the roll bar to the wind shield and give s upward curve to the top so that water will mot pool and then run off the side in a big mess.
But that is just what I do.
Carl
I like/have the strap type. I have footman loops on the sides of the top rail on the tub, They're where the tonnu cover bows hook. Works for me. The roll cage supports the middle, so no pooling, and the cover goes on if it's left out.
