Additionally, please do not confuse Bio Diesel to running Straight Vegetable Oil (SVO) or Waste Vegetable Oil (WVO). There are BIG differences.
Bio Diesel is a diesel fuel product made from Soy, Canola, Peanut, etc... The viscocity is very similar to regular diesel. There are no modifications needed. The only thing to worry about is your source for BioD and whether or not you have problems gelling in the winter. Gelling fuel is a bad thing.
SVO or WVO requires modification. It requires 2 tanks. One for the oil and the other for regular diesel (or BIO). The vehicle starts up on DIESEL and runs until the OIL is heated to the proper temperature. Once the OIL is hot enough that the viscocity is similar to diesel fuel then you switch over to run off the OIL. If you do not do this you will mess up your fuel injection pump among other things. Your fuel system is not designed to run that thick oil. It's also common to switch back to the DIESEL a few minutes before shut down to clear the lines of the SVO or WVO.
While there are some similarities, these are very different options in fuel for your diesel. Be careful to seperate them when doing research and getting information about what you are going to do.
I don't know if anyone watches the Discovery channel show called "Dirty Jobs"...but there is a great one running right now where the guy goes through the whole process of making BioD. He got his oil from a mexican food restaurant. But it's quite the process and a little chemistry to boot.
