Blower motor identification help
SurfnCJ8
Wilmington
NC
Had to change my heater core and since it looks like my firewall had been cut I thought I would try to determine if the PO had done the blower motor upgrade or not. My old one has "Unimotor" on it and part #11554. Advance could not cross reference that for me. Grabbed the new one since I was there and I can return it. It is part#35587. So my question is can anyone tell from the olsd # if it has already been done? The motors appear to be about the same size. I will try to add a pic here in a few minutes. Thanks!
Might be just as easy to measure the diameter of the hole in the firewall. I just did the blower motor upgrade on my 7, and used a 3-1/4 in (83mm) hole saw.
The hole in the fiewall looks to already have been cut, Since a couple of people owned the jeep before me I am trying to figure out if the motor that came in i t when I got it is an upgraded one or not.
Can you get a measurement of the diameter of the motor (without the heat sink)? I'd also be sure to double check the shaft length as well. I see where many people order the wrong one, and the fan (squirrel cage) rubs inside the heater housing.
Thanks for finding that, I will double check the old and newer motors there this weekend before I put things back together. I Plan on using the hardtop and driving it this winter so want to have as much heat distribution as I can get.
Got the new blower motor in over the weekend. Off today so started checking things before I put t all back together and it only blows on high. First thought was blower motor resistor because that happened in our LJ but I do not recall seeing one in there anywhere. I only have a hanes manual but i will check it and crawl around the jeep and see if I see one . Now my battery died ( LOL ) so I have to check that too.
You're correct, it typically is the resistor or switch.
From the FSM:
