Any chance you want to share that file? I can cut them on my plasma.I just finished this swap on my EV-converted 8. I used a gen 2 iBooster supposedly out of a '21-23 Tesla Model S. I took measurements of the booster mounting studs and the firewall mounting holes and worked up simple brackets in CAD and sent them off to SendCutSend. The pushrod threads on the booster are metric of course (I removed the factory clevis) so I got a metric-to-imperial female adapter nut from McMaster and attached my existing pedal connector so there's some adjustability. The brake line ports on the booster are also metric so I got a pair of adapters for that too. Wiring was simple using the harness mentioned in a previous post. It's dead silent, pulls near zero power when idle and under 10A with normal braking. I can lock up the brakes but the pedal feel is softer than I was anticipating. With it off the pedal is very firm. From my online research this seems to be the nature of these things and may actually be vehicle-specific CAN-programmed. There are folks out there working on CAN controllers for these so maybe there will be something available soon that allows for easy adjustability. I did bleed the snot out of it and the bore on these is 26mm so right at 1". I'm going to take it to a local brake shop next week and have them look everything over, test the pressure at the calipers, etc, just to make sure it's optimal and safe.
Happy to, what file type do you need? One thing to note is that the I did it doesn't include a relief cutout for the pushrod boot area. I had one in the design but SendCutSend would do the bends because it would apparently deform it. So I removed the relief, had them cut and bent without it, then cut that area out myself.Any chance you want to share that file? I can cut them on my plasma.
Any format would work.Happy to, what file type do you need? One thing to note is that the I did it doesn't include a relief cutout for the pushrod boot area. I had one in the design but SendCutSend would do the bends because it would apparently deform it. So I removed the relief, had them cut and bent without it, then cut that area out myself.
I don't mind at all. Here's a couple different formats (wouldn't let me attach them here directly)...Any format would work.
If you don't mind, I'd like to put them on the Irate4x4.com file share?
Sorry to be so late to the party, I too didn't know all the drama surrounding Pirate but thanks for posting the info elsewhere - BUT, using your link, there is not picture on that page - could it be due to my recent registration to that forum, you know, restricted till I do 50 push-ups and spin around 32 times or something.https://irate4x4.com/resources/ibooster-gen-2.53/
If you needed dimensions.
There's also an adapter that I've cut and used.
Damn. I’d love to read that thread. But I just can’t take jeepforum anymore. Good lord, it’s like the ads have ads in them 😳Sorry to be so late to the party, I too didn't know all the drama surrounding Pirate but thanks for posting the info elsewhere - BUT, using your link, there is not picture on that page - could it be due to my recent registration to that forum, you know, restricted till I do 50 push-ups and spin around 32 times or something.
If you could, do you have your instill pictures, I'm VERY interested in putting it in my CJ-EVC (my build: https://www.jeepforum.com/threads/jeep-cj-7-ev-conversion.4455457/ ) to be a potential replacement for those customers that want Power Brakes.
There are two versions of CAD files linked in my post above, are those what you're after? Also, just a heads up, I mentioned in another post that I did cut out a relief area in the brackets (pictured below) to allow for the booster pushrod boot b/c SendCutSend didn't like it (something about bending with that area cut out would have deformed it).Sorry to be so late to the party, I too didn't know all the drama surrounding Pirate but thanks for posting the info elsewhere - BUT, using your link, there is not picture on that page - could it be due to my recent registration to that forum, you know, restricted till I do 50 push-ups and spin around 32 times or something.
It's a CAD file you can download:Sorry to be so late to the party, I too didn't know all the drama surrounding Pirate but thanks for posting the info elsewhere - BUT, using your link, there is not picture on that page - could it be due to my recent registration to that forum, you know, restricted till I do 50 push-ups and spin around 32 times or something.
Do they, I don't get them, maybe it's because I'm registered, don't know. BUT, hands down, they have the deepest bench of knowledge over there.Damn. I’d love to read that thread. But I just can’t take jeepforum anymore. Good lord, it’s like the ads have ads in them 😳
Damn, it's a STEP file, I've got to update my TurboCAD to the latest version to get that.
That mounting flange CAD file is cool, thanks!There are two versions of CAD files linked in my post above, are those what you're after? Also, just a heads up, I mentioned in another post that I did cut out a relief area in the brackets (pictured below) to allow for the booster pushrod boot b/c SendCutSend didn't like it (something about bending with that area cut out would have deformed it).
Thanks.Oh wait, I see the GREAT write up on IRATE (very cool take off on Pirate, someone's proud of themselves for thinking of that one!).
This link: https://irate4x4.com/threads/ibooster-electric-brake-booster.394316/
WOW, so much there!
Laughing!!!Thanks.
I am Mod/Admin there. We all worked together to get the P out.
