- white lake
- MI
Oct 1st is rapidly approaching and, well, I did something stupid, stupider , stupiderer, and even stupidererest...AND NOW I NEED HELP!!!
Stupid: I let a coworker convince me to join her in a 63 mile, 5 member team relay thru the woods / swamps / hills and lakes of michigan (craig it was the trials at Poto). I said "yes" because this is and area reknowned for having HUGE deer and i hoped to see one....
Stupider: Two miles into the race I sprained my left ankle. I knew it was bad because two miles later it had swelled over the top of my shoe. When I found an aid station I had the choice of letting my teammates run my milage or continue.....
Stupiderer: I continued. Self medicated and tightly self wrapped (the medical staff wouldn't do it unless i promised not to run) 11 more miles and finished my portion of the race, after all how much worse can a sprain get?...
Stupidererest: I let my wife talk me into going to the doctor 4 days later. Turns out the main bone (talus) that connects your leg to your foot is broken. 16 weeks in a cast to the knee and "NO CLIMBING OF TREES OR HIKES IN THE WOODS".
(Im sure if i HADNT seen the doctor it WOULDNT have been broken).
As you empassioned, like minded BOW boys must know, this is NOT an option so I need to rig a harness of some sort to pull myself up into my stands. I have a small bit of climbing gear and knowledge but wondered if any of you have been in or had friens in similar situations and engineered a safe way to get into a tree without the use of a broken leg. I could hunt from the ground but...
Any ideas would be greatly appreciated, T minus 15 days to opening.
Stupiderererest Scott
(Im sure if i HADNT seen the doctor it WOULDNT have been broken).As you empassioned, like minded BOW boys must know, this is NOT an option so I need to rig a harness of some sort to pull myself up into my stands. I have a small bit of climbing gear and knowledge but wondered if any of you have been in or had friens in similar situations and engineered a safe way to get into a tree without the use of a broken leg. I could hunt from the ground but...
. And he says I should only need an air cast after that.
