bright alternative for those OEM front turns
groundworks3 said:
if I wire it one way only parking lights, the other way only turns,
I did LED brake lights and had similar issues. I found a diagram on the web somewhere that explained the wiring, don't know if that would be helpful for these (maybe similar just without the brake light wire?) not sure where I found it though, just a thought for you to try.
Thanks I'll try that, but my wiring has been a problem since I got the jeep, my factory turns worked the same way, this problem isn't just because the LED's,my fender turns are parking lights only, if you short the wires out then they work as turns, someone else put the new harness in, & some where there is a short, the gauges didn't work so I got new ones, then about a week later they all shorted out, tried a new fuse instantly blew, so I'm just riding around w/o gauges for now, I'm used to it anyway I've had CJ's before, I don't think I've ever had a gas gauge for more than a year!! I'm pretty easy going & patient, my friend has a service shop, he LOVES tracing down shorts, so when he has time this will be for him, because, I can't seem to find it, but for now I just fill up every Friday, have parking light only on the fenders, & turns only in the grill, at least I have a working system for the road right!!!!!!:D
Should I go with LED lights?
Sounds like a great way to improve your road safety, while saving some money, too!
I'm not a mechanic like most of you guys, so I rely on my friendly neighborhood Jeep mechanic in Worcester.
Most of my dashboard lights (heat, lights, vent, etc) have burned out. Mechanic says they don't make them anymore. Says they won't install anything "after market". Says I'm basically stewed.
Where can I get lights similar to the originals, or LEDs, and can I do this myself?
Cheers, gents,
BigLittleTim
ebay item # 120194492281, this is what I was tossing around, I was thinking of mounting these behind my dashpad, mounted to the metal of the face of the dash, with the LED facing downward, & I all wiring would easily be routed behind the dashpad, with a drill hole & rubber grommet, then I would trim the dashpad to fit aroud them, so these are not noticeable at all, & when on, they "cascade", down the entire face of the dash, the idea came to me when a city cop pulled me over at dark & asked if I knew how fast I was going, all I was thinking is, "NO clue I can't see my dash after dark"!!!!!!!!!!:christmas
Just my thoughts, probably more than you are after, definitely not an overly fast fix, but a clean finished alternative, & they are marine grade, so who cares if they get wet!!!!!thats what I liked about this idea!!!;)
Originals still available from most jeep catalogs (ie. 4Wheel Drive Hardware), and easy to install.
Keep in mind the marker lights flash with the front lights when the lights are off, and flash opposite of each other when the lights are on (like it's being shorted).
I realize the side markers are "supposed" to flash alternatly, mine just don't & have never since I have owned it, (unless you short it out)
Looks like those all mount flush.
If so that would be really sweet for my little M-416 trailer. I can mount them to the frame but not have to weaken it by cutting out for the light.
Thanks for that link.
Also thinking about that for semi flush mount tail lights on the CJ
Carl
I realize this is an older thread, but has anyone nailed down how to wire the 2 wire LEDs for park/turn lights?
