AK-RWC
- south central
- AK
My son was “helping” me in the garage and asked about the engine hoist, so I showed him how it operates. Maybe a week or two later, both kids were in the garage with me playing with the hoist; just jacking the arm up and releasing the pressure. I ran upstairs for something and heard a loud crash followed by crying. My wife and I ran down to the garage to find that my son told his little sister to pull on the lifting arm chains while he jacked. Since the legs weren’t attached, the arm came down...onto the ZJ. Thankfully neither of the kids were hurt, and the only real damage was to the right side turn signal. (That fiberglass bumper pulled through yet again!) Since we’d been tossing around the idea of new headlights anyway, this was the motivation I needed to get it done: all new assemblies for both sides.
I called The Retrofit Source ("TRS") prior to ordering because I was concerned about an LED not having enough heat to melt snow/ice, but I was attracted to the M-LED 2.0 because it didn't require a separate harness. After doing an informal poll among Jeep owners here, it was apparent that LEDs were only icing up during times when halogens were icing up too, even with the factory LEDs on the JLs/JTs. So, since the LEDs had much smaller drivers to mount and were otherwise plug-and-play, I ordered them up with the 9004/9007 splitters (recommended by TRS), and selected the FlatBoy Switchback shrouds, mostly because they were somewhat rectangular and would provide a nice transition from the round projector lens to the rectangular ZJ housing. It turns out that the LED also gets quite hot; hot enough that Morimoto incorporated a cooling fan for the heat-sink. This means that there's an internal fan circulating warm air within the housing. I'm hoping that any concerns I would have otherwise had about icing will be completely nullified.
Since you can't put a projector into the factory housing since the OEM Fresnel lens would simply kill the benefits of the projector's beam, there are a couple of aftermarket ZJ housings available that are a "euro" style and provide a clear front. I ordered these Anzo USA 111066 housings from Amazon. Into the oven they went so soften the butyl rubber so you can pry the fronts off.
Front off. Next, remove the bulb cover thing that's screwed in.
Then, down to the garage to quickly open up the 9004 hold to H4 diameter using a die grinder and a carbide bit. I also decided to bring the rear mounting surface down about 1/2" to have a few more threads for the back of the projector to screw to. I used a flat-file to make sure it was all still at the same plane.
First mock-up of the projector inside the housing.
Both projectors more-or-less ready for baking with new butyl rubber.
OEM headlight on bright on the left, with the M-LED 2.0 on bright on the right.
There was, however, a snag. Not knowing the differences between a 9004 and a 9007 bulb, I assumed that since they're sold as the same splitter, it was simply a design change or wattage difference on the filament side. So, since TRS said this was plug-and-play, and the only directions anywhere for this are on their website (and Morimoto's) for how to screw the projector into the housing, I simply tried the plug and play. The dims were on bright, and when I tried swapping sides I ended up melting the connector and I heard sizzling coming from the driver. I immediately sent an email to TRS and went to bed. In the morning, after going back and forth with their tech support, I tried one more time using my multimeter to make sure I wasn't doing anything "wrong" since it's possible to flip the polarity for the driver input (TRS said this was an intentional design since some Toyotas are reversed). Sure enough, I fried the other driver. I called TRS and they said that the first advice I got was wrong; that the "older Jeeps" did need the relay harness. TRS had that, and two new drivers, on the way at no charge the next day.
I’m pretty anal about checking for it in crappy weather.
