Wayne
- Cape Coral
- FL
Hello :
Is anybody familiar with the two idle needle valves at the bottom of Carter BB2?
I have had an ongoing issue with the carburetor running sluggish at high speeds for quite a while.
I found out yesterday that one of these screws adjust the idle when the vehicle is standing still, and the other adjusts the idle at speeds?
If I run the engine and turn each screw in individually, both of them will stall out the engine, but I don’t know which one I turned to make the engine run smoothly at high speed.
When I get to about 40/45 miles an hour the engine starts coughing and spluttering, and I believe one of these needle valves can fix my issue I just do not know anything about them and I’m having a hard time finding anything about them on good old Google.
Thank you very much
Thank you very much
