I rebuilt a non-stepper Carter that came on my project Scrambler before I disassembled the whole Jeep. It made a world of difference No real difficulties, fairly simple rebuild, and I am by far NOT a carb expert. Two suggestions:
1) I would suggest buying the metal gallon can of carb cleaner, so that you can completely submerge/soak all the pieces overnight.
2) Pay special attention to the little air bleed tube things. I suggest buying an oxygen/acetylene torch tip cleaning tool. It has the right size wires to run down the tubes to clean out any build up.
Good luck with your rebuild. Get comfortable, take your time, stay organized and you will do fine
well i got it done.... it wasn't to bad. Thanks for the tip on the cleaner got it from Oreillys for 25$ well worth the money....... I couldn't believe i didn't have to adjust it at all after I put it back on, just fallowed the directions and set the float, accelerator pump and pick up tube as instructed.
I cant believe the differences, how smooth it idles and no more low rpm stutter!
