Charcoal Canister
joshvt
Scrambler Enthusiast
charlotte
nc
A few months ago, I replaced the stock carb with an MC2100. In the process of removing and replacing vacuum lines i broke the nipple off my evaporation (charcoal) canister. I couldn't figure out an easy fix and I didn't want to eliminate it like some do, so I decided to replace the canister. The purge valve on these canisters is susceptible to dry rot and that can cause a vacuum leak- so I wanted a new vs. used one.
It didn't take long to figure out direct fit replacements are not available. I spent a fair amt of time researching and reading multiple forums looking for an alternative. Each time I found a write up with model number, the model was discontinued. I found some threads on IFSJA where guys had used a GM replacement (Napa Part# crb 229805). this unit is bigger, so the bracket has to be modified and it has two purge valves- the unused would be capped. I ordered this unit- unfortunately I just upgraded my brake booster/ MC and the brake lines would not allow it slide in to place. Long story short I ended up digging some more and found a replacement Advanced Auto Parts #cp1109. This cannister has the needed connections, but is a smaller diameter than the stock. It has a sealed bottom with breather port, which seems better than the open filter material on the stock canister. To make it fit the stock bracket, I bought a 4" rubber pipe coupling and cut it into two strips- this provides a spacer that allows the stock bracket to grip the canister.
I haven't driven it a ton, but it seems to be working great so far- and there is no gas smell in my garage.
Evaporation canister replacement is not the most exciting project, but maybe this will help someone out who is searching for a replacement.
Here are some pics.
Original vs. New Comparison
New-top view
New w/ Spacer before cutting spacer
Installed
Great job and write up. Your correct, you check the forums, someone lists a part number and it's discontinued. This will help someone.
Nice write up. Too many people do not understand the need for this critical part and just rip it out and then complain about fuel smell for the next ten years. This absolutely should never come out.
Yep- I searched extensively for a BWD CP1061. Looked like it would be a perfect fit. Could not find one anywhere.
I did not need to do any drilling- once I figured out how to secure it in the stock bracket, it was an easy install.
I will be selling the larger one that I never installed- let me know if interested.
Great info! I ended up epoxying the nipple back on my broken one since I couldn't find a replacement.
Thanks for the info... My original is in bad shape and needs to be replaced, after seeing your post I ordered mine from AA 64.99
I left it as is. I meant to put a hose on it and turn it up 12” or so like a snorkle. I forgot and didn’t feel like taking it out to do that. Reality is I won’t be going through any water that deep.
Joshvt- Received my Geo canister installed it over the weekend. Followed your recommendations on the Frenco 4" coupling work great... I did bring the vent up and used breather cap. Thanks again :thumbsup:
new purge valve
If your actual can isn't split, you can just put a new purge valve in-line. They are about $6.
