Charity Jeep Support....
Kaiser8 said:
I'm going to go out on a limb here and say that what you have has nothing to do with "hot" fuel. Sounds like a sensor/electrical problem. Take Ken's advice and pull codes before you do anything else.
I agree...at least about the not running good till it hits steady state...the not starting problem...not sure...but havin the codes pulled should be the first thing you do..
wait..one caveat...just on the off chance that it is vapor locked fuel line...have someone hold the bleed valve while u cycle the fuel pump..and see if any air is there
To check and see if it is a fuel problem, just pour a soda cap full of gas into the carb - oops, it's that darn new fancy F.I. system (Fouled-up Injection). Every once in a while I'm glad I still have a carb. :D
Sorry I just couldn't resist.
that is a thought..could put a cap of fuel in thru the throttle body and see what happens
While you are at AutoZone getting your codes read, rent for free a cylinder pressure test gauge.
Then at home with the engine cold, crank each cylinder and take a cold cylinder reading. Don't forget to:
a) disconnect the spark plugs
b) disconnect & plug the incoming fuel line to the fuel rail which is the red nippled line ithe MySunnShine's photo (or disconnect the fuel pump).
Then tell us what each cylinder's cold reading is.
Since it runs rough the first 2-3 miles and then clears up, it could be that you have low pressure when cold until it heats up. If this is the case, the OBD scanner won't give you any codes.
I've called Hesco today and talked with Lee.
He said put a reader on it to see if it has thrown codes. He said it's an OBD I.
With a fuel pressure gauge, I'm getting 42 psi without cranking it but cycling the key on.
However, 42 drops down to about 38 after about 10 - 15 minutes.
The bleeder valve on the pressure gauge allows you to bleed fuel into a jar or something through a clear line. It appears there is air in the line. Don't know if that is vapor created due to heat when it was last parked or if it's ingesting air into the system perhaps in the pickup of the tank. Either way, I should not have air in the lines at the fuel rail. I've got to figure out where the air is coming from.
Hey Bud, I could be wrong but that sure sounds like a CPS problem. We dealt with an issue like this on my 2000 XJ and my buddies TJ. I think you are on the right track, read the codes.
Another thing you can do is use a spray bottle, have someone crank the engine a spary fuel into it. When it is running like crap, does it seem to be running rich? or Lean? Does it seem to be miss firing?
It is backfiring every now and then whilst trying to crank it.
I'll have to check codes.
I'm hoping I'll have some time to dedicate to it this afternoon.
Back firing? this is a timing issue. the only thing that controls timing....map sensor. Check your vacuum and the timing. there will be a timing/computer disconnect. disconnect it and check the timing and set to 0. reconnect. then check your vacuum. check for vac leaks too.
If memory serves me correctly it drove home 500 miles with out a problem. Several members drove it dozens of times without any problems. This being said I wouldn't think it was due to fuel lines or exhaust being too close to anything or it would have been a problem before now. Air in the fuel lines is common. Fuel aireates when you pump it or pressurize it. Heck even the old cj's would have half air in the clear filters you would see in the line. With it backfiring through the exhaust this can mean only one thing. It is firing a cylinder when it's not supposed too. It is trying to fire a cylinder when an exhaust valve is open thus causing a backfire. It is most likely a electrical problem and I'd guess 90% a crank position sensor reading the crank wrong. Ken adams replaced one on it already when they had it for running poorly and they are prone to fail all the time on xj's and tj's. Take the old one off and take it with you as there are several different plugs on the end of them from different years. Go get one and put it on. Will most likely fix it
No Timing Adjustment
On a 4.0 there in no timing adjustment. The distributor does not rotate, it bolts in solid in one position, the timing is set by the computer. Look at the CPS. That's what I had problems with on my 4.5 stroker.
Don
Oh, Its bolted into the top of the bellhousing on the drivers side. Should be a 10mm headed bolt. It's not adjustable so just bolt it in. Some early ones were adjustable with an air gap that had to be set but not yours.
If none of this works and you just wanna git it out of your yard call me and I'll come haul it off for ya:D
Backfiring? That's new info... my earlier advice (about low cylinder compression when cold but running fine after warming up) doesn't really apply anymore (unless there are two issues).
Did you ever get the codes read? What were they? (it's amazing how fast that will isolate the subsystem where the problem is).
I have MPI also with the 4.0HO head too. Seems somewhat strange that you have backfiring & rough idle/driving until it warms up -- that once it warms up, both the backfiring and rough idle go away.
Are you sure it really is a true "backfire" and not just an incredibly rough idle where cylinders are missing/skipping? Kind of like the engine is "coughing" when you're cranking it.
If it is "coughing" and not truly "backfiring", a couple other things that would cause a "coughing" condition when cranking or when cold:
- Map vacuum line accidentally got disconnected.
- The TPS (throttle position sensor) electrical plug that inserts into the intake manifold at throttle body is disconnected. (code 24 results from this and other things).
scrangler said:
It is most likely a electrical problem and I'd guess 90% a crank position sensor reading the crank wrong. Ken Adams replaced one on it already when they had it for running poorly and they are prone to fail all the time on xj's and tj's.
We replaced the TPS with a used one we had.
We DID NOT replace the CPS. That seamed to cure the bucking at that point in time.
We are not real sharp on this kind of stuff.
I think like most, it's trial and error or process by elimination.
Sorry not much help.
CPS huh....
Y'all are awesome!
I will be absolutely covered up tomorrow with a HUGE EVENT our club puts on every year and Jennifer and I, as y'all might imagine are pretty involved with it.
Sunday will probably be the next time I can take a look at it. I will go pull the CPS this evening so I can take it in with me to the parts store on Sunday.
If it doesn't fix it, I've got a spare and that doesn't sound like having a spare would be a bad thing.
It is definitely a BACKFIRE and not a sputter. Jennifer said the dog almost wet the carpet in the living room!
The guy trying to crank it (me) almost wet the drivers seat. :eek:
Any other thoughts on the MAP sensor and where it's located? Isn't that the one thats just above the valve cover on the firewall or the one thats on the passenger side of the throttle body. (I know the one on the back side of the throttle body is the TPS)
Thanks for all your help!
... it's trial and error or process by elimination.
It doesn't have to be. As many have advised, get the codes interpreted. That will more than likely identify the bad sensor.
Later, Ken
Headed to the garage...
Headed out to the garage now....
New CPS. We'll see what happens. If nothing, I've got a spare.
Gotta do a little wire splicing to get the length I need to the connector up on the front of the wiring loom that runs parallel to the fuel rail. Plug is up front near the thermostat housing.
Woo hoo!
She runs again!
Musta been the CPS. Fired right up first time I tried. Pressure holds around 44-45 when running, bump the throttle, and it stays pretty steady. I'm going to take if for a little test drive and report back findings shortly. Cross your fingers.
When I get back, pending no problems, I'll let it cool and go ahead and shift all of those fuel components on the gas tank crossmember as far as I can to the drivers side to get them away from the exhaust that is now on the passenger side....just to be safe.
