Charity Jeep Support....
CJ8LVR said:
She runs again!
Musta been the CPS. Fired right up first time I tried. Pressure holds around 44-45 when running, bump the throttle, and it stays pretty steady.
So what happened to:
CJ8LVR said:
However, 42 drops down to about 38 after about 10 - 15 minutes.
Just changing the CPS will not effect your fuel pressure-
That was without it running. It would not hold pressure with the key on but not running. I'm guessing it would do the same now.
I'm not worried - it runs again. I went and took it for a test drive and it ran without any sputtering etc. The only thing I heard out of the ordinary was when shifting from second to third... just as I applied throttle again and let out the clutch, there was an ever so faint backfire though the exhaust. Did it two or three times. It wasn't loud at all.
I pulled it into the driveway to let it sit for a while and cool down. I'll go drive it again here shortly and that I think will be the true test to see if this fixed it.
