Chev 350 Carb Recommendations
Dave K.
Milwaukee
WI
Folks, I've been battling with tuning my Rochester Quadrajet on my 71 Chev pickup and am reaching my limit.
Have the timing set up correctly, think I have the mixture tweaked as well but it continues to give me idle fits after warmed up (example, drive it, stop at a light and it dies--taking off from a light it is equally as finicky). In addition, once warmed up if I shift into drive or reverse (it's an auto) the thing dies as well.
Question--Anyone have recommendations on carbs to replace the Quad? The Quad is rebuilt and Im bummed to have pissed the money away but I need the truck reliable for my junk runs and so on. The 350 is bone stock and I don't really want a monster since I'm running a stock cam--just something fairly effecient and reliable (and easy to set up). Something in a 650cfm I guess.
Anyway, if someone has something they want to sell that would be great as well.
If I'm missing something let me know!
Thanks, Dave.
I personally would keep the Q-Jet. You just need to make sure that the throttle shaft bushings are not worn out, the body itself isn't worn, or have any internal leakage. But if you want to go to somthing else, either the Edelbrock or the Holley works. They both have their problems.
Thanks for the input. I shot some carb cleaner around the shafts and the rpms went up so I assume they are worn. I'm going to just pickup a new AFB and be done with it I think.
In addition I would like to get away from the points--any recommendations on drop in electronic systems to replace the old distributor?
Put a Pertronix unit in the distributor. They work pretty well. While it's out, disassemble it and clean/lube it and make sure the bushing in it too are not worn out along with the weights/pins. When you put the carb on, be sure to put a thermal spacer on it because they are prone to boiling the fuel-
