Rjsimms
- Chesapeake
- VA
All, I am new to the forum. I have read and learned alot. I have been into Jeeps a long time. I currently own an 05 TJ with a few mods. I have always liked the CJ 8's. I ran into an operunity to purchase one. It seems in rough shape but does have potential. It is an '83. It has the original AMC 304 with Automatic trans. The engine accoriding to the owner was rebuilt a few thousand miles ago. It seems fairly accurate, it starts and runs strong with no oil leaks, or in the trans. It has the stock Dana 20 rear end, and Dana 30 front. It has had a spring over conversion lift installed, The body is in fairly bad shape, as seen in the photos' THe rear end will need to be rebuilt, the spider gear shaft end broke while it was in motion and locked the rear end up. It is sitting on after market wheels and 35 inch tires. The full hard top is available, also. The owner had started to take it apart for resoration, but has changed his mind, my question to the experts how much is this thing worth in the condition that it is in? Also, the only guage that works is the speedo, the heater does not work either.
