- Corvallis
- OR
Can anyone out there with factory cruise tell me how the wiring is run down the column? I'm looking into retrofitting factory cruise into my Scrambler and was wondering if the wires from the turn signal switch run down the inside or outside of the column. I don't have the hardware yet but what I'm planning on getting is a control switch from an early 80's AMC that will replace my turn signal lever. All the one's I have seen have a short bit of wire with connectors that wouldn't be long enough to get down the column. The ones I have seen use a 4 wire system. I'm hopping I can combine this with a YJ 4.0 engine system that will hook up to the Mopar fuel injection kit I have. Anyone out there with cruise from either of these systems who can tell me how the system is wired and if they think they would be compatible?
