CJ Cruise
Going Postal
Corvallis
OR
Can anyone out there with factory cruise tell me how the wiring is run down the column? I'm looking into retrofitting factory cruise into my Scrambler and was wondering if the wires from the turn signal switch run down the inside or outside of the column. I don't have the hardware yet but what I'm planning on getting is a control switch from an early 80's AMC that will replace my turn signal lever. All the one's I have seen have a short bit of wire with connectors that wouldn't be long enough to get down the column. The ones I have seen use a 4 wire system. I'm hopping I can combine this with a YJ 4.0 engine system that will hook up to the Mopar fuel injection kit I have. Anyone out there with cruise from either of these systems who can tell me how the system is wired and if they think they would be compatible?
Get out of my head
Craig,
I have been thinking about this very thing since I now have to drive 30 miles every day each way on the interstate to work.
Maybe out to put this on engine or restoro forum?
I will watch this with interest.
I'll start looking here for the hdwe and if I find 2 sets, I'll let you know.
Later
The wires run down the inside of the column. I finally collected enough parts to put the factory cruise on mine. They're laying in a box waiting. The only CJ specific parts are the bracket that mounts the actuator on the fender and maybe the wiring harness and cables. The rest of the parts can be obtained from other models. You can find nos turn signal/cruise switches on ebay. There's one up right now.
http://cgi.ebay.com/ebaymotors/ws/e...&item=7961658547&rd=1&sspagename=STRK:MEWA:IT
I don't know if you could integrate the original switch with the later 4.0 system, haven't researched that.
Greg
