cj8 vs cj10
motas
Melbourne
VI
Hi. Selling my TJ atm to get a cj. I either want a cj8 or a cj10, both of which are fairly rare. I am aussie so the cj10 (j10 here) is 119 inch wheelbase with dana 44/60. Cj8 will either be an overlander or scrambler with 30/20. I will be building it up for sunday driver, hardcore trail rig and touring which makes things a bit tougher. So it needs to handle nicely on the road so will be doing coilovers front on a cj10 or coilovers front and rear on a cj8. Interior on either will be retrimmed with a custom dash complete with head unit and various switches and plugs, most notably 240v ac, 12v dc and usb plus music inputs for sound system. Either will get a nice orange paint job and every little bit I can painted to stop any chance of rust. That should cover the road driving every few days. For touring I need enough space for gear for a month or so in the outback and would also like a rtt/camper with kitchen, fridge, comfy bed and some other little things to make it a bit more comfortable for the long hauls. I will be custom making it but it is a consideration for the size of the vehicle whether it will fit. For the trail riding the coilovers should do nicely for flexyness and looking to run 37s. Over here it is mostly mud and ruts and its too easy to hit the pumpkin on smaller tyres. CJ8 are generally cheaper than the 10s and are weaker but look better and are easier to find.
So with all this in mind which do you think I should go?
Thanks.
Will the RTT be permanently mounted or on when you're wheeling? I wouldn't want a RTT on a coil sprung Scrambler on anything other than a dirt road, too tippy unless you limit the suspension so much you negate any benefit from coils or go to wide axles that would otherwise compromise usability I would think.
I don't see why you feel the need to change out the leaf springs in either case anyway. For less money, get some well built leaf springs (Alcan comes to mind) and leave it at that. You can call Alcan with the specs on your rig once it's all built and get something set up perfectly.
One thing sticks out, I would never run 37s on stock, or even built, 30/20 axles, so you need to figure an axle swap in there IMHO for the Scrambler/Overlander.
I think this would come down to which one you can find in the condition you want but the -10 sounds like it would be better suited to carry the weight you're looking at and would have suitable axles stock. I would think you could make either work well though.
Regardless, I am :popcorn: for the build thread!! :cool:
RTT/camper (depending on which one suits best) would normally be on only for longer/easier trips depending on how light I can make it. If it ends up being large and heavy I wouldnt take it into the bush and risk damaging it, id just take it on outback trips. Adjustable coilovers with swaybars should handle fairly well if setup properly shouldnt it? I have almost no experience with leaf springs and from what most people say about them id be better off with a coilover conversion. From my experience with coilovers they can be made to handle very well. But I am open to your opinion you obviously know a lot about cj8s which most people i have spoken to do not.
Yes that is a big problem for the scrambler having to switch diffs. The only diffs I can buy cheap and easy here are nissan patrol diffs. They are very strong but do have a large pumpkin which makes the 37s pointless compared to 35s on a smaller set of diffs. Ideally id be looking for a 44/60 which id either spend a long time finding or have to buy them from the states. Cj10 has this already so is a big plus to that.
Right now I have found two cj8s for sale and two cj10s. One 8 is in the same state as me but is in very bad shape and way to expensive, the remaining three vehicles are basically a two day drive away each way and look to be in good condition at a reasonable price. But I do not get my license for another 6 months so need someone else to drive up and back which is proving to be some trouble.
I much rather the look of the cj8 over the 10 but as you say the 10 is more practical for the diffs and weight carrying. Have you ever seen a camper setup on a cj8? I think it might just be a bit small. The other advantage of the 8 is the option to have rear seats on shorter trips.
I cant wait to get started either but I really need to be patient and find the right one which im not good at. And be warned i make almost no money, it will be a VERY slow build but I am really looking forward to it.
Thanks.
PS I really like your cj8! The stance of it just looks great.
Oh, coilovers can be done to ride great, don't get me wrong! But you're looking at removing all the stock spring hangers and having to install a 3 or 4-link setup from scratch. There are no "kits", so you're looking at custom fabrication and it needs to be done very well/properly if you're talking about a lot of road driving.
All I'm saying is that you're looking at a ton of work and expense to do that when leaf springs are a simple couple hour swap once you order the right ones. Alcan (and I'm sure others) can build leaf springs specific to your rig's weight and intended use. I love the way my Rubicon Express 4" kit rides. Just drove it 4 hours one way for wheeling this weekend and took it to my company's main office 4 hours one way a couple weeks back, perfectly comfortable IMHO. My LJ rides "better" of course, but it's 21 years newer.
OH, I misunderstood, you mean a camper in the bed? I don't think you're going to get that to work without some serious fabrication. I thought you meant a trailer you'd pull. Trailer will be WAY easier. For what you're talking, I'd stick to a RTT on an Overlander.
Given your money comment, I think you've got some seriously ambitious plans, but nothing wrong with getting something you can build into this. Good to think ahead to what you ultimately want to have, helps avoid spending money needlessly.
Thanks for the compliments on mine, I took a long view like you're doing with mine and tried to buy smart/used and sell things off as I went so I didn't waste much money.
Three links are relatively simple (i said relatively :)) but 4 link id have to get done professionally. I can always buy a set of good leaf springs and see how they are because you are right its a lot of cost and effort for something i dont know how much better it will be. But these are simply preliminary plans and a lot will change during the build. The only thing i really know is what i want it to end up doing, so at least i can base my plans on that.
I doubt a camper would fit in the bed of a cj8 but one would definitely fit on a cj10. Thats another thing that changes between each model. A cj8 id pretty much be forced to run a rtt with the remaining things i need in the back or make a camper for the back of a cj10 which would replace the tray/tub. Either way would work fine but just a different way of handling things, the cj10 with a camper would be a more elegant solution though.
Hopefully I will be making a lot more money soon and this will be a very long term project. Basically ill start by rebuilding it with paint and a major service. The paint is basically free for me because my brother sells the stuff and hell do the actual painting for free and i can do all the rebuilding myself so that bits easy. Then ill get a moderate lift and tyres to get me going and then it will just be a bit at a time when i can afford it. I have a fair bit of time though and plan to do all the work myself which saves a lot of money. We have a workshop with hoist, mig, plasma and all the hand tools and things i need to take on pretty much anything.
I was thinking something similar to this for the cj10:
http://www.expeditionportal.com/forum/threads/20822-Sönke-s-hard-side-popup-camper
You know what I think your right. For what i want the load carrying capability, space and diff strength of the cj10 makes it a winner.
Thanks.
