Crown 21 gallon scrambler incompatibility?
I can't imagine any reason it would not fit. There was never a CJ8 specific gas tank from the factory. Only difference was fill hoses
Agreed. Unfortunately Crown does not give a reason. I've found some discussion threads in different forums suggesting the extra four inches in height would make it possible for the rear axle to hit the tank. It's close just eyeballing it, but I'm not sure how close or how different the CJ-7 axel center to tank is different than the CJ-8.
The extra six gallons would be great. But, buying a $400+ paperweight sounds less great.
I have a CJ7 20 gallon tank in my Scrambler. It is close to the rear diff when flexed, but the only issue I had was the choice of aftermarket diff covers. Some would interfere, some would not. My Riddler covers fit fine.
Thank you. I've also seen that there was a OEM 20 gallon tank offered on the scrambler. Not sure how the Crown 21 gallon tank differs from the OEM 20 gallon tank. I'm not looking to get aftermarket diff covers, but it's good to know how close the OEM tank is.
Oem 20 gallon is plastic like the crown, but it is wider and not as deep. It also has a different skid plate than the 15 gallon. It is 4 sided, not just a front to back piece of sheet metal.
I think the crown one uses the stock 15 gallon skid plate with extension brackets.
Thank you for your feedback. I feel like this Crown 21 gallon tank has about a 70% chance of working and a 30% chance of frustrating me with a side project this jeep doesn't need at this time. Looks like I'm going with a metal 15 gallon tank. Doing a frame off restore and got to the point of ordering the tank because the old plastic one cracked. This CJ-8 will become a tow vehicle for a small camper therefore lowering my MPG.
You could always switch out later to a used stock factory 20 gallon unit, with the original installed now.
Yea, metal factory style tank is $300 cheaper. Could get some nice jerry cans.
@Interceptor What are those white wheels do you have on your profile pic? Wanting to get rid of my wagon wheels but stay steel.
You should be able to find a stock 20 gallon for $300. Might try the Jeep recycler in Georgia. So, unless the 15 gallon metal tank is free, I can’t see how it is $300 cheaper.
The Crown 8128585PLXL goes for $400+
Stock metal tanks go for about $100+
There's the $300 I was talking about.
I've not been to the jeep recycler in GA and not finding much on the web about them. The aftermarket 15 gallon plastic tank I am replacing cracked/died after about 10 years. Not sure how I would feel about a 40 year old plastic gas tank.
All of my OEM plastic tanks have been in excellent condition (after cleaning out the remains of the sending units). I trust all of them explicitly.
Here is one of my tanks in the cleaning process.
You can look on the previous page to see what came out of the tank.
