Dana 60 Worth?
Is it a front or rear?
I've seen the rears go for as little as $100-$150 for a stock axle, but usually a little higher. Fronts are a lot more expensive.
4.10's are pretty common I think. Is it 30 or 35 spline? What vehicle did it come from?
It is a rear full float out of a 78 Dodge power wagon. I think he said it was a 35 but not sure on that.
Here in Texas, no more than $100, and that better be in good condition. Now if you pull a shaft and count 35 splines, it's worth over $200. But that's very unlikely.
i bought a rear for 76 dollars. and it had a factory posi..fronts are about 10 times that.
Gotta love SET.com
I know the guys that set that site up - programers anyway.
Here they go for around $500.00 and up if they are complete and in good shape for the rears............and have the good stuff in them...............fronts complete will start around $800.00 and if it's a HP then your getting into the $1100 to $1500 range :(
Looks like I need to load up on $30 axles in Dallas and import them to Tennessee then. Nobody drove trucks there in the 70s and 80s?
Then you have the other side of the spectrum. Building a whole new front 60 :D OUCH.
Well I bought the front Dana 44 but not the rear 60. it was in perfect shape but after doing some study i found alot more 14 bolts. I have one here that I am almost done with anyway. Got a good 14 bolt with 4.10's and Gov Lock. I put disk brakes on it and is ready to go. The front d44 off the dodge will work perfect. It is 8 lug also and 4.10. Probably wont have them on by this Scrambler event but will by next year. This year I am just going to have to baby it :( Still have stock axles.
Yep they did,but we don't have bone yards here and since 4 wheeling has been big here for many many years,guys found out early about sticking one ton running gear under their jeeps,just not many of them to be found that are complete.........every once in awhile you get lucky and find an old truck with a 60 under it,but most have been striped........lot of the old trucks and cars where crushed back in the 80s under the gov programs to rid places of old leaking cars and trucks and eye sores.............
Crash said:
Then you have the other side of the spectrum. Building a whole new front 60 OUCH.
I feel your pain brother! ;)
