Dash overlay removal...
1BADCJ8
Silver Member
Silver City
NM
Any one have an easy idea or know of an easy way of how to get that thick glue off there?
The plastic outer part cracks off really easy but that thick arse glue is really on there, its like a sheet of roofing tar on there....lol. Thanks.
maybe I heat gun or some sort of solvent
trial and error
Take it off in layers. Spray on a light coat of wd-40, lets sit 5 minutes and then rub with a plastic dish scrubber. Repeat as necessary (may take 10 or 15 cycles. As you get closer to the paint, ease up on the pressure. Doing this way should end up with a nice clean and shiny paint job where the plastic piece was.
If you have everything removed and aren't worried about the paint job, just use a wire brush wheel.
WD40 and elbow grease did the job for me. I did not use a dish scrubber- but that would have sped up the process. I also used goof off- until I realized it was taking off the paint on my dash panel as well.
Best of luck
Kyle
3M makes a spray specifically for removing vinyl striping that doesn't attack the paint. Maybe it would work. Maybe mineral spirits. OR replace the overlay with a new one.
Paul
Thanks guys good suggestions. I am replacing it with a new one with out the radio hole but you cant just put it on with out removing the other one first.... way to thick.
Eric, how big a mess did that make?
WD-40 strikes again :D . Get the good stuff...lol
It should be less than 1 roll of paper towels. Lay down a tarp below the dash so wd40 doesn't get over everthing else in the jeep.
Since you are planning on covering with a new overlay, suggest using a razor blade vice the dish scrubber. May get a small scratch here are there, but nothing bad. Once you get it down to a thin layer, then just use a paper towel. Make sure you wipe up with some alcohol or mineral spirits good to remove any WD-40 residue.
I used to have a chemical company and sold a chemical called "orange-sol". Most sign companies use this to remove glues. I've used it myself many times to remove glues, adheisives and various types of sealants. It works extremely well and is non-toxic to the touch...but don't drink it. If I remember correctly they were out of Gilbert, Arizona and their phone no. was 1-800-877-7771. The info is a few years old but the product is still out there. Good luck.
Steve
