SCJeeper
- Pickens
- SC
Like the title says....ever since i put the dash back in during the rebuild I am having some issues. Example....my new oil pressure gauge actually looks smoked on the inside, volt meter is not working properly, and the fan speed switch is not working at all. All of these worked previously before the dash came off.
A little back story may help. During the tear down I removed the dash and labeled all the wires as I unplugged them from the back of the dash. The one snag that I ran into was when removing the dash was when trying to remove the black wire (I'm assuming the ground wire) the bolt that it was on was stripped so I cut the wire thinking I could just put a new wire connector on it when I put the dash back in and everything be honky dorry......WRONG! Moving on....I painted the back of the dash for rust prevention and not that anyone can see but so it would look better. So I get the dash painted and ready to put back in with some new pretty componants and plug everything back in the way it was labeled and HOLY CRAP nothing worked. When you turned the lights on both signal lights would come on, when you adjusted the dimmer switch the oil pressure and volt meter gauges would go from one end to the other, non of the dash lights worked and no radio. So after banging my head in the wall for a couple of hours I decided to hook everything up then progressively start unplugging things until it started working. I plugged the antenna in the back of the radio and wam bam thankyou mam everything worked. CLUELESS!!!! I know that something is wacky because now nothing has changed but the battery and oil gauge do not work and the fan speed does not work. I'm at a loss please help!
Thanks,
Brett
Thanks,
Brett
