DC electric motors
wm69
Silver Member
God's Country
AR
School me on potentiometers.
Backstory...have a Minn Kota trolling motor. Didn't work first time out this year. Took it apart, found the magnets in the bottom end had come loose, breaking one in half.
Discovered repair parts are no longer available for this motor, soooo being the "Hate to throw things out" guy I expoxied the mognet back together, and then expoxied the magnets back in the motor housing.
Still nothing. The control board in this thing is completely covered in a black rubber like substance, but I suspect when I tried to get the motor to run with the magnets dislodged I burnt up the control board.
Took the + and - wires going from the board to the bottom end and connected them to 12V and the prop spins fine, just at full speed.
Was thinking of trying to hook in a potentiometer in place of the factory control board. Something like this should be enough amps to hold up right?
http://www.ebay.com/itm/10-50V-60A-...005&rk=4&rkt=6&mehot=pp&sd=191453025152&rt=nc
Next question would be forward and reverse. I'm guessing that hooking the battery leads up backwards would make the motor run backwards, right? So potentially, could I get a FWD/OFF/REVERSE switch and hook the leads up with + and - leads going into switch, + and - leads coming out of proper terminals coming out of the switch and then reverse the + and - leads coming out of what would be reverse?
Not sure if that makes sense, or even if this whole idea will work. Just hate to toss if it I can rig it to work. Figured with the wide variety of folks here who like to tinker that someone would have an idea.
Edited to add, thinking about it again, there are two red wires and two black wires going to the bottom end of the motor. It would be logical that one set is for forward and the other set is for reverse. If so, that would make wiring up a switch much easier (assuming I could find a switch that wouldn't be huge and would be capable of handling the power....guess I could always use a relay).
I had one, same brand, that did the same thing. Looked great, was the 3 hp model. I had it checked out and told it wasn't fixable. I ended up tossing it eventually after it sat around a few years. It was great, when it worked.
From what I've seen the new ones use a lot less power, are quieter, and I think I paid about $400 for that 3HP motor back in the day, and it's supposed to put out about 48lbs of thrust. I can get a new Minn Kota 55lb motor for $210.
Guess that's how the govt claims inflation is under control. Too bad one can't eat trolling motors and big screen TV's.
Anyhow, think I'm going to buy that board listed above and try it, just out of curiousity.
The wife offered to buy another trolling motor (she likes to fish) so this one, if it works, would probably go to backup role.
