Has anyone removed their stock heater and replaced it with a Vintage Air or Hot Rod Air unit? What did you do to block off the fresh air intake from the cowl?
Well, I am doing the same thing, and have one idea to fiberglass the inside vent holes in the cover and then put a bead of silicon on the cover. I would really like more options
Working on that exact thing right now. I am going to attempt to chop the airbox so I can still get some fresh air if I want. I mounted my Hot rod Air unit as far to the passenger side as possible. Killed the glove box but left plenty of room for a stereo and gauges. If that doesn't work I was thinking of using one of the flat aftermarket stainless vent louvers with a thin sheet of stainless sandwiched/sealed between it and the cowl.
With this being my first Scrambler....Is the factory heat really that bad? Even with the chevy fan upgrade?
If you mount the Hot Rod unit in the glovebox area, could you put louvers in the factroy glovebox door and vent the hot air out that way? Yea it sounds crazy
Probably cook the passenger.
The only reason I am not using the factory heater is because I redid my dash and got rid of the heater control cables. Also the factory heater and ac would not work with my engine swap. If I could keep the stock stuff, I would go with the Blazer blower motor like I did in my last CJ8. Now I have a vintage air dual zone ac to keep the dogs cool!
My factory heater seems adequate as is. Of course, I have the inline six which probably generates more heat than the four cylinder engine, and I live in the South where our winters tend to be milder than the Northern climes.
Been talking to Jim Wilson at http://www.custombilletworks.com/ He says he can make one with or without holes, no problem. I will get Madjp62 to drop off example. He says cost will be depend on how many we would want
I wrote Jim and will be giving him a stock one to copy, he wrote:
Hey David,
Look doable! Yes, I would need one for a little while so I could reverse engineer it. No problem on the fake slots.
You could also ship one to me if you want.
How many people want these? The price per part will depend greatly on how many we do.
