Electric fans for CJ Radiator....
$16 bucks!!!
You should have seen the poor guy that had to pull my fans. He spent 30 minutes taking the front of the engine apart to get them out. They are made to come out from the bottom. I am sure he wasn't making $75/hr, but he got his hands dirty. I am always amazed at the price variations for used parts. I have bought Dana 44 axles for $100 and $400. Exact same axle just different locations. Locally, the price of the Contour fans varied from $75 to $150.....
I got my fan control from http://www.a1electric.com/catalog/cat_spal.htm
It shipped out the day I ordered.
SPAL is adding a couple of features to the controller and a lot of resellers are out until May. I don't need the new features(24V, more preset temps, etc...)
Later-
Trouble mounting on a 3-core radiator....
From JEEP1:
I'm trying to get mine installed but I'm having some real clearance problems. I have the OBA and there is no way the fan is going to clear the York compressor. Does the fan assembly go inside the frame of the radiator and what do mean when you say, "my fan is mounted on the front side of the grill"? How far away from the radiator mounting flanges are the mounting tabs on the fan when you have the fan assembly installed on the radiator? Also, do you have a 2 or 3 core radiator? I have a 3 core. When I tried to mount it to the radiator today the frame of the fan assembly rested on the o/s of the radiator not down against the core, not that it would have made any difference. The mounting tabs on the fan were about 1" away from the radiator mounting flange. I tried the fan assembly alone(w/o the radiator) and it still hit the York and the mounting flanges were against the radiator support on the jeep. I haven't removed the cover from the pass. side fan motor yet but I will tomorrow but I really don't think that will fix the problem. I got the fan assembly from a mid-90's Mystic(sp) but the part # shows it's the same as the Contour. I'm stumped!!!
Response TOM82CJ8:
Sorry to hear you are having trouble. I bet I have a 2-core radiator. The fins are recessed about 1" from the rear frame of the radiator. I cut the upper tab off of the contour shroud. I removed the radiator mounting nut tabs from the grille and put them on the radiator flanges, then I put the radiator inside the grille. With the radiator inside the grille I was able to wedge the countour shroud into the radiator face frame. The tabs on the contour shroud are flush with the back side of the grille. I used some self-tapping screws to mount the shroud to the grille. One of the shroud tabs lines up with the radiator mount bolts. I drilled a hole in that tab and ran the radiator bolt trough it. With everything mounted this way I have about 1/4" clearance from one of my belts and the clutch on the York. I had to remove the metal fan motor cover from the passenger side and grind a couple of the plastic screw mounts from the shroud by the face of the York clutch. So if you can get the countour shroud flush with the back side of the grille, you should have enough clearance.
Later-
Tom
My install experience was exactly like TOM82CJ8's. Fit perfectly. Like he says, probably you don't have the stock radiator.
Jeff
electric fans
Yeah, it sounds like you have a 2 core because the fins on mine aren't that deep and the tabs on the shroud like about 1/4" touching the mounting flange on the radiator. I'll try putting the radiator in front of the grill and spacing it forward about 1/4", if there is enough clearance, and then I could mount the fan shroud on the back of the grill.
I used this sensor and also have a three pos switch...
http://store.summitracing.com/partdetail.asp?part=FLX-31147
I used the Taurus Fan and have been really happy with it. All you have to do is set the temp onthe knob of the little controller and have a switch position wired and you are off and running. I have mine set up to follow the temperature sensor, off, and high. High is to cool down really quick and the follow the temp of the coolant is great for normal on road driving. The Taurus fan setup has been great for cooling my carbed 350 for the past 4 years now. I have a full schematic and spreadsheet showing costs and all if anyone would like to see it. My total out of pocket with everything down to wire and terminal connectors was $99.XX. Cool project!!
Make sure you have all hot wires relayed and not tied directly to the switch in the cab... We don't want any fires!!!
Here is a wiring diagram of my fan controller setup if anyone is interested...
I used an 03 malibu dual fan setup. Install and fitment was just as good as yall are describing with the contour fans. For whatever reason, the regular taurus fan everyone says they use would not fit between the 258 and 3 core radiator. I had moved the radiator about 1" forward for more clearance also. The malibu fans were nice and thin.
I didn't get fancy on the controls. Just an autozone controller that controls 2 30 amp relays. The only problem I've had was poor connections on the spade terminals of the fans. Next I see a malibu in the yards I'll get the stock plug.
Tom or Jeff could either of yo post photos of how you mounted your radiator on the front side of the grill?
I've got a 3 core radiator and the york OBA using the kilby brackets and clearance is very close.
I was able to trim the fan shroud down and gain some clearance, have the fans sitting out about 2 3/4" from the radiators mounting flanges. If I've eyeballed it correctly I need to move the fan forward about 1/4" to get the clearance I need for the fan to fit.
For the fan controller I'm going to modify the one I made and is currently have setup for my dual fans. The controller currently is setup for one fan on, off, or on at set temp, the other either on or off.
Since i got resistor with the fan shroud I want to set the fan up to run as a dual speed. I have not though about the switching options except what are the best tempts to cut on or off.
What I'm wanting to do is place the temp sensors, one for low speed the other for high speed, near the out put of the radiator and use the temp of the coolant coming out of the radiator to determine if the fans need to run. Is this a good idea or do i need to base the temp on what is coming out of the engine. I know that most of the time for street driving my fan does not cut on, I'm using a 195* thermostat and the temp switch is set at about 210 with the probe near the radiator inlet.
My thinking is to only run the fans when needed and to cool the coolant down just enough to absorb the extra heat with out a major swing in temps between what is entering and leaving the engine.
RJ-
It would be hard to get a pic of that location. Basically, I removed the threaded tabs from the grille and put them on the radiators mounting holes. Then I put the radiator inside the grille. Then use the mounting bolts to pull the radiator into the backside of the grille. If you need more clearance, you can put washers between the radiator and grille.
I read somewhere that reading the temp of the coolant leaving the radiator is not preferred. I am reading the temp with a sensor in my intake manifold. This is where the GM TBI reads it, and also where the Jeep computer used to read it.
Let me know if you need more guidance.
-Tom
sorry to hi-jack your thread - but . . .
jscherb said:
Yes, that's the one.
To answer the override question: I'm using the DC Control controller. I constructed a little control panel for the fan, see photo. Switch has three positions - normal (letting the DC Control unit decide how fast to run the fan), Always On (runs at 50% or more depending on cooling needs) and Always Off (you might use this for a water crossing). Top LED glows from green to yellow to red as fan speed increases so you always know how fast the fan is running. Bottom LED glows red in Always Off mode.
I wrote about the fan install in this thread: https://www.cj-8.com/forum/showthread.php?t=18579
attachment.php
in your picture you have a check engine light. Where can I get one? Been looking on line but have never seen them offered - just the 6-pack of the other lights.
You can bet that Jeff made that "Check Engine" light. Pretty cool!!!
I replaced one of the screws in the steering column shroud with a red LED. Works great. Also, it doesn't require an additional hole in the dash.
Later-
Later-
Yes I did make the Check Engine light. I posted instructions somewhere on here, I'm sure you can find them with a quick search. I think the artwork is posted in that thread also, if it isn't let me know and I can send it to you.
As for the fan mounting, mine is mounted on the engine side of the radiator, you asked for photos of fans mounted on the other side, correct? Because I have the stock radiator, my fan fits fin between the radiator and the engine.
Jeff
