Electric Winch
mrachal
Conroe
I have installed 2 warn electric winches on my Scrampler. A Warn 9000 on the front and a WARN 6000 on the rear in the space between the gas tank and the rear of the jeep. My question is How do you have your winch grounded? To the frame or did you run a ground cable from the battery to the winch? I would like to finish this part of my project by the weekend, Input needed.
Mike Rachal
Due to the large current requirements of the winch, connections should always be made directly to the battery. Due to the extra distance to the rear of the Scrambler, you may want to run one or two sizes larger than normal to help reduce the voltage drop.
I've thought about adding a winch to the back, but can't figure out how to remote the engagement handle. Want to mount it on the skid plate where its up between the frame rails.
Do you have any pictures of your install?
Kohldad I could take a couple of pictures and e-mail them to you if you sendme a e-mail add.
Mike Rachal
I have a warn 9500 ti in the rear. I used a larger cable and ran it about 2' to the frame. As of yet I haven't had any problem at all. I think you'll be ok going to the frame as long as everything else is well grounded
I'd think you can make this work, but I'd have some SERIOUS ground cables between the frame/chassis/engine/battery if I were going to try.
