some progress...
Well today was a little progress I suppose. Started to paint the rocker gaurds and hope they will dry by wed enough to install. I wouldn't say they are my greatest work but I'm satisfied with them. I had debated on using spray on bed liner on the inside of them but I was afraid the thickness of it would mess up the bolt holes so I simply went with etch primer and some industrial enamel rattle can gloss black. Figured they will get dragged across rocks one day so maybe the touch ups will be easier.?.
Also got to work on the seats in between painting. For those that don't remember, I nabbed the seats of Ebay and they are heated leather buckets from an '02 Pathfinder. I had a harder time removing the factory mounting feet than I did getting them to fit. The Nissan folks really must get excited about fastening stuff. They were screwd, riveted, and spot welded onto the sliders...Holy COW!! Once those were off it was really easy-ish. I had some 3/16sX3" flat bar which worked out really well. The Nissan seats rails are about 3"s wider than the CJ ones. I welded the flat bar to the Nissan seat sliders after cutting them into 14" lengths. I then set the seat in place and maked the jeep holes with a sharpie, drilled, and Ta-DA! Fits perfect! Not a lot of room to recline the seat but certainly no less than the horrible Rugged Ridge seat I took out. I didn't have enough metal to do both sides so tomorrow I will try for that box to get checked.
One side note of interest is that the Nissan seats have the female end of the seat belts built in to the seat. I could have removed that but on a whim I just tried the CJ belt into it and what-do-you-know...it fits! So I will be looking pretty close to see how good it all works out and if luck is with me I will just use the Nissan females and remove the Jeep ones from the floorboards. That may give me a little more room to work in some sort of center console. The factory plastic one really is nearly useless IMHO.
Sorry I didn't get a chance to get any pics today but I will try to do that in the morning.
The early part of this week was pretty miserable for El Paso. It snowed on Mon and tues and while the snow wasn't really all that bad, the ice was. Mad for some nasty driving and brutal temps. I, like any good jeep nut, spent Wed. in my unheated storage unit tearing appart my "spare" 77 dana 44 for the flat top knuckles. Got those sent off to Parts mike and am hopint they will be done and returned ASAP. They are also going to make the tyerod and drag link as well as some more stout u-bolt plates. Mike is an amazing resource of information if you can get him on the phone. I was concerned about some of the strange components on the axle I have and he has been talking me through making it better.
The hysteer will obviously help the steering issues but I was concerned about having some semi-odd parts (Scout) that may be even harder to find if I need replacments. Not to mention that some of the things don't interchange and some have been "modified" by the PO in ways I am not sure about. To that end it looks like the final result will be something like this.
Dana 44 with the 77 waggy knuckles. I will use either the waggy or CJ8 (Dana 30) spindles which are 6 bolt (easier to find/common GM) and retain the Scout hubs. If I understand all this correctly, I will be able to use the scout rotors and the waggy's calipers. That is supposed to be a better caliper as well as I will then be able to use the braided and extended brake lines from my full size jeep parts bin. They are new but I don't think they would work with the Scout style caliper which would make me start hunting custom lines.
Mostly it all seems a little confusing but very do-able.
I also scheduled an appointment with 4wheel parts to have them install the detroit/4.10s in the rear axle on Thurs. I will drop the jeep off wed pm or thurs am depending on work and hope all goes well there. Then it is driveshafts, rear brake line...and bits and parts here and there. Time is almost gone so I'm trying to wrap up what I can. Should be a fun project that will continue while I am in Germany...I hope!
