First post and wanted to say Hi to ALL!!!!!!!!
you sure? I have the pic showing up on this end. You shouldn't have a problem getting rid of the Bench. i have seen several looking for one.
yes sir I realy don't like the bench that much and I think I am going to replace it with buckets later.
IT WORKED!!!!!!!!! IT WORKED!!!! YOU ARE THE MAN!!!! :D
Good deal that is very clean CJ8 you have by the way. Do you have any plans for it? It looks great now.
Dan
I think I am going to put 35X12.50X15 on it and a 4" lift will be my first things after I fix a few leaks. It is a VERY solid 8 but the rear dif leaks and the steering box leaks which I plan replacing very soon.
Mine leaked in those same places, as well as a few others. :rolleyes: 33's will lo good on it. Are you going to be able to make it to Hot Springs? This will be my first year there.
I am always up for a road trip and I wish I could but I am in TN and I can't get off work long enough for trip like that. :(
Now I'm depressed....VERY VERY NICE 8... I love the flares. I would love to add them to mine. By the way I add a few more pictures to that web site so if you get bord check them out.
that really is a tight looking ride you have, If mine had looked like that I would not have torn it down. I also do not know that I would do it again :rolleyes: Well, maybe. My old doge ramcharge is getting retired and the 8 will be my daily driver. It was rust free but had a hard life till i got her. well, off to bed enjoyed talking with you.
Dan
Welcome
That bench looks cool...but I don't think I could give up the Tuffy center console for it. Once again...welcome aboard...looking forward to tracking all of your projects in the near future.
Speaking of...BigWalton turned me on to a 4.5" lift here recently that you might want to consider. It's a pretty sweet lift that takes care of just about everything.
http://northridge4x4.com/proddetail.php?prod=RE5525
JPdeuce
Thanks. Do you have that lift on you 8? I was looking at buying a skyjacker 4" kit but I realy don't know the difference between any of them :confused: except the lift size and I was told I should go with a soft ride kit. I plan on driving it mainly on the road for now. Will I have to do a body lift in order to run 35's or will the lift be enough to clear the tires even on rough ground?
I used a 4Plus shackle reversal system and 2.5" Old Man Emu Springs. I have about 2000 miles on that before I tore it down. It cost alittle more than a just a lift but the ride is great. I would recommend it to anyone. It was a little work to get the shackle reversal on there but it was worth it. i gues quality control at the Jeep plant was a bit light in the 80's :rolleyes: .
The more lift you add to the springs the rogher the ride. Mine will be on the road 99.9% of time so ride was my main concern. The whole shackle reversal and lift springs gave me right 4.5" of lift and the 1" body allowed for 25" easily. If you want 33" tires I wouldn;t do the body lift but I would replace my 25 year body busshings anyway ;)
Dan
