ScramblerTN
- Lenoir city
- Tn
The lift is bds 4.5” with M.O.R.E 3/4 or 1” shackles ( can’t remember exactly). No shins that I can recall unless they came with the springs. To be honest I don’t really know if the Jeep will re-center itself. I just haven’t driven it that much.If they give you your caster, yes, you’ll know if you’re in spec there (and it’s a good idea to get an alignment after the lift anyway.) But what was done relative to caster with your lift? Any spring shims added? What lift is it?
When you’re at lower speeds, does the steering want to re-center itself if you turn it (like if you turned slightly and took your hands off the wheel)? Too little caster often results in no return-to-center feel in general in addition to high-speed wander.
