- Woodway
- Tx
What's next? I'm dreading having a finished project and nothing left to fuss with.
That’s when you get a 2nd one.
Gorgeous, and about what I hope mine looks like when I'm finished later this year. I haven't forgotten the tonneau you sold me way back when - it's going to good use and our cjs will have that small bond.
Are your decals from Phoenix Graphics? If so, were you happy with them?
I did get the decals from Phoenix Graphics and from what I can tell they are the exact same graphics that were on the Jeep originally.
I’ve got a bds 4.5” with .5” shackles ( can’t remember brand name of shackles) bfg mt 33x12.5. I have room for 35s but it still had stock gears....for nowI like they way your Jeep sits, what size tires and lift did you go with?
I like the chrome. But having the others gives you options. ?Ok need opinions on wheels. My scrambler came with the original while wagon wheels ( including the spare). A friend of mine gave me a set of the chrome wagon wheels that the clear was pealing off and said I can have them if I wanted to clean them. I stripped the remaining clear off of one and buffed it and it looks great. Bling bling! I like both wheels..especially like that I have a matching spare on the white wheels but white wheels will need to be blasted and powder coated... But chrome will need to be waxed to keep from rusting without a clear coat![]()
VS.
Opinions??
I will be using it mostly for a full length bikini top
Thanks. I’ll definitely keep an eye out for that. I do have a few extra bolts for the rail from a bestop hardware kit I bought for the cj7 so I could always add a few more and have all the hardware matchJeep looks fantastic
This is how I use mine mostly. Watch the side rails bending up (pulling away from the tub) where the front edge of the rear corner of the top comes down to the rail when you're driving with the windows out. (circled spot in photo) The rail mounting bolts are too far away from that spot to lend any strength and the corners catch a lot of wind as you drive, pulling up hard on that spot on the rail.
I saw a ridiculous amount of bending there and one corner pulled loose from the rail so I decided to add one sheet metal screw through the rail into the tub (on the angled edge of the tub/rail) at that point. Fixed the bending completely and kept the "long bikini" top much tighter when driving.
On another topic..I’m having trouble getting my steering dialed in. I’ve probably not put more than 100 miles total on the Jeep since restoration. It has all new steering and suspension components...gear box,shaft, drag link and tie rod. Gear box brace, steering stabilizer etc. It still has a lot of slop in the steering. I’m not expecting a Cadillac ride but my stock cj7 with mostly original steering rides much better. I have not had an alignment done yet. It drives straight down the road but side to side at higher speeds is a little scary. Do you guys think an alignment would make a difference? Any other thoughts?
HMMMMMM.... Can't stress it enough - if done incorrectly you'd get exactly these symptoms. I ran into them myself when I replaced my ball joints. If the torquing procedure is done out of order - even if all the torque specs are correct - you'd see exactly this. I'd keep it on the list. If the caster is OK, then consider the ball joints.It’s not easy to describe but at highway speeds...over 45..it feels like it I’m white nuckles to keep it between the lines. Ball joints were replaced during restoration.
